HELP with my 1998 Dodge Ram 1500
Old Mar 19, 2012 | 02:37 AM
lilmamma's Avatar
lilmamma
Default HELP with my 1998 Dodge Ram 1500
I have a 5.9L V8 Dodge Ram 1500. The code P0301 popped up on my OBD2 reader. I went and bought new spark plugs and wires. Yet the code is still coming up. What do I do?
Old Mar 19, 2012 | 08:10 PM
jasonw's Avatar
jasonw
Site Moderator
https://dodgeforum.com/forum/dodge-r...s-section.html
Old Mar 19, 2012 | 08:27 PM
sam_priem's Avatar
sam_priem
did you do the cap and rotor? if not, that's probly the next place to go. they are cheap enough and fairly easy to replace.
Old Mar 19, 2012 | 08:41 PM
Matt Nickerson's Avatar
Matt Nickerson
You erased the code first right?
You could also throw in a compression test on that particular cylinder.
If you replace the cap/rotor and still get the code. Check the voltage on the injector and make sure it isn't clogged. This'll usually throw an injector code but not always, so check it out.
Old Mar 19, 2012 | 11:19 PM
lilmamma's Avatar
lilmamma
I just replaced the cap and rotor today and the code came back....
Old Mar 20, 2012 | 12:19 AM
Jason_Dodge's Avatar
Jason_Dodge
Erase the code silly. then get back to us.
Old Mar 20, 2012 | 01:05 AM
lilmamma's Avatar
lilmamma
lol.... i did erase the code silly came on half hour later....
Old Mar 20, 2012 | 02:31 AM
kissmymagnum's Avatar
kissmymagnum
Look for broken vacuum lines or possible leaks, also, were the plugs covered in oil or carbon when you changed them?? That would point at an intake plenum problem..
Old Mar 25, 2012 | 04:26 PM
lilmamma's Avatar
lilmamma
update, cap and rotor replaced, replaced two vacuum lines, cleaned the throttle body, checked the distributor, erased the code, now random misfire and cylinder 1 misfire are popping up... i have 4 days to re-smog the truck... so confused even had a guy come look at the truck he couldn't find out what was going on either because the truck is running fine, no sputter or misfire.
Old Mar 25, 2012 | 04:27 PM
Check your plug wire routing, there is a TSB in the faq section for proper routing.
