New to fourms with some questions
Old Mar 26, 2012 | 11:55 PM
COL's Avatar
COL
Default New to fourms with some questions
Hi all, I am new to the fourms and had a few questions. First I should start and tell you my ride. I have a 1996 Dodge Ram 1500 4x4 SLT Laramie SPORT with fully loaded with the 360ci Magnum engine. I love my truck. Its black and in really good shape. I will have to post some pictures some time. My question is with the Infinity Audio. I recently wrecked one of my speakers when tearing my door apart. I was really happy with the sound that came out of them, so I kind of wanted to stick with them. I went to my local salvage yard and found no rams with infinity audio, but i found a Jeep Grand Cherokee with infinity audio. They are both 6x9 in the front doors. I need to replace my passenger door speaker, and got the one out of the drivers door of the Jeep. Will these speakers work for me just plug and play? I dont want to cut or splice my factory harness in my truck. any help would be great!
Old Mar 27, 2012 | 12:06 AM
gdstock's Avatar
gdstock
Can't really tell without looking. I would think the connectors are the same. Did you look at them?
Old Mar 27, 2012 | 07:07 AM
Ham Bone's Avatar
Ham Bone
While the infinity speakers were great back when the truck first came out, they are getting old.
A good set of aftermarket speakers wouldn't run you too much money and you would get better quality.
Old Mar 27, 2012 | 07:13 AM
dhvaughan's Avatar
dhvaughan
they might work. look and see if they both have the on-board amps attached. your problem might be a bad amp, and not a bad speaker.
see the AV subforum for lots of info.
https://dodgeforum.com/forum/audio-v...-speakers.html
Old Mar 27, 2012 | 10:15 AM
COL's Avatar
COL
I figured I would give it a try, I only paid $5 for the new speaker from my local salvage yard. I will have to pull my door pannel off and see. Does anybody know if the drivers side and passenger side connectors are the same?
Old Mar 27, 2012 | 10:16 AM
Should be exactly the same, aside from the color of the wires.
Old Mar 27, 2012 | 10:21 AM
COL's Avatar
COL
Ok thanks. Hopefully Jeep used the same connectors as well!
Old Mar 27, 2012 | 12:24 PM
COL's Avatar
COL
I pulled my door panned off and took the speaker out. I have 4 wires running to the factory amp mounted to the speaker, then two coming outbid the other side. No connectors it is just soldered from the factory to the amp and to the speakers. So I guess the jeep speaker won't work. So now's my next question. What kind of speakers are recommended to replace the stock ones, will I need new tweaters (I assume mine are wore out by now too) how do u wire the new ones in (because there is 4 wires going to it) and am I going yo have to amp my new speakers to get good sound? I do have a aftermarket deck already installed.
