For power i tapped in to the Cigar plug, then for dimming lights i tapped in to the proper wire in the headlight harness. ground i ran to a good spot then just ran my gauge wire through the fire wall with all my other friggin wires... Going to take a day and rewire all my lighting and radios.
160 was the highest I have seen in my truck since the temp gauge install. I am also running full synthetic (valvoline) ATF.
I dont know if you mean AFT fluid or AFT+4 but...
Did you know that all the ATF+4 is the same synthetic formula... it has to be made to the same standards to get licensing from Chrysler.... So any brand from the $5 to 9$ a quart will really have the same performance....
Yuppp, figure take out my splice and add an extra filter and cooler.... or.... since i will be making 6500 every two weeks... sell her and get a BRAND new dodge... cummins... fully loaded... If al works out that is lol...
