Midway Through Plenum Repair
Old Apr 8, 2012 | 11:12 PM
  #81
Augiedoggy's Avatar
Augiedoggy
yup thats it, ... and intact... if the gasket were the source of the leak the oilstain would show ere it was leaking and coming in.... being that the whole maniold was covered as well as the plate it looks to be a spray pulled in from the pvc.... just my thoughts on it though... the gasket does look like it was shifted in a couple spots but not enough of a gap to cause that I think...
Old Apr 8, 2012 | 11:18 PM
  #82
Ham Bone's Avatar
Ham Bone
Well I'll have dad get me a PVC valve because he works at a car dealership.
At least I already fixed the hard part
Old Apr 9, 2012 | 09:09 AM
  #83
Ham Bone's Avatar
Ham Bone
Now I can't get the theemostat to open up.
Old Apr 9, 2012 | 09:18 AM
  #84
Probably an air pocket just under the stat....... typical.
I would think that if the PCV system were the primary culprit here, you would see most of the oil opposite where the fitting for the inlet line is, which isn't the case here.... nice uniform covering at the front, and MUCH heavier at the rear.
Also, just because the gasket is 'intact', does NOT mean it wasn't leaking. My valve cover gaskets are intact, but, they still leak....... (yeah, I know, I really need to change those......)
Old Apr 9, 2012 | 09:24 AM
  #85
Ham Bone's Avatar
Ham Bone
How do I get the air pocket out? Yeah I almost jumped on the valve cover gaskets but decided not too.
Old Apr 9, 2012 | 09:26 AM
  #86
What i did, was run the engine at like 1500 RPM, to "pack" the coolant into the engine. Yeah, it has a pretty high 'pucker factor', but, so long as you don't get into the 'red' on the temp gauge, should be ok.
Old Apr 9, 2012 | 09:28 AM
  #87
Ham Bone's Avatar
Ham Bone
How long did it take?
Old Apr 9, 2012 | 09:30 AM
  #88
just a couple minutes, once it actually started warming up.
Old Apr 9, 2012 | 09:32 AM
  #89
Ham Bone's Avatar
Ham Bone
I'll have to give it a try again, it got a little too close to that red line the first time
Old Apr 9, 2012 | 09:33 AM
  #90
Yeah... that's where the pucker factor comes in.
