clicking in rear of 97 1500
Old Apr 6, 2012 | 09:36 PM
z7 extreme's Avatar
z7 extreme
Default clicking in rear of 97 1500
It happens when I am accelerating. goes away when I let off the gas. The more I give it, the louder it gets. Sometimes it doesnt do it and sometimes it does. Any ideas? Thanks in advance
Old Apr 6, 2012 | 10:49 PM
Check u-joints first....... if that is ok, pull the cover, and have a look. Does your truck have the trac-lok rear diff??
Old Apr 7, 2012 | 01:33 AM
z7 extreme's Avatar
z7 extreme
Not sure how to tell what rear end I have, or how to tell if the u joints are bad. Sorry guys I am a novice at this.
Old Apr 7, 2012 | 01:42 AM
dhvaughan's Avatar
dhvaughan
park truck on level ground.
block wheels in both directions.
parking brake off.
transmission in neutral, engine off.
-- make sure its no going to roll --
-- all tension is off the drive line --
inspect u-joints closely.
check that the grease seals are present, and not cracked.
grab the 2 sides of the joint and try to twist them.
any wiggle movement at all in the joint means its bad.
if it passes the wiggle test, stick a long heavy screwdriver through the yoke and pry on it. again, you want no movement.
you either have an "open" diff or a "limited slip" (LSD).
you can look for the old sticker on the axle tube, or the sticker in the glove box or under the hood. the LSD's have clutches which can wear out.
Old Apr 7, 2012 | 01:50 AM
z7 extreme's Avatar
z7 extreme
Thanks again, I will check for play in the u joints. I cant imagine why the rear end wouldnt be a limited slip, but again I am not sure. I will post back as I know this post could help more than myself.
Old Apr 7, 2012 | 09:22 AM
LSD rear was optional on most trucks. (standard on the Off-Road Edition.) Not as common as I would have liked. (my truck doesn't have one.....)
Old Apr 7, 2012 | 08:53 PM
z7 extreme's Avatar
z7 extreme
After riding in the back of the truck, it seems the clicking is coming from the middle of the truck, and not the rear end. Ill have to wait to figure it out until I replace the fuel pump that went out today Thinking maybe the u joints on the front of the drive shaft?
Old Apr 8, 2012 | 10:58 AM
Possibly, do you have a center support bearing on your driveshaft? (two-piece rear driveshaft...)
