Transmission Help
Old Apr 9, 2012 | 05:39 PM
white7wolf's Avatar
white7wolf
Default Transmission Help
Okay so I've spent about 6 hours or so combing these forums and haven't read a story quite like what my Ram is doing. I have a 99 half-ton quad cab 4X4 with a 5.9L V8. Here's the issue:
Roughly 65% of the time it drives fine. It shifts perfectly. The other times the check engine light comes on and the transmission will NOT grab 1st. I believe it's going into limp mode. I have tested it quite a bit and second, third and overdrive catch just fine.
So far, we have replaced the governor pressure parts (the solenoid and the regulator I believe) and that's it. I can't remember the code off the top of my head but the description was something to the tune of "Governor pressure out of bounds". I can get the exact code tomorrow if need be.
I'm hoping you guys can help me out and this is not an extremely deep rooted transmission problem. I bought this truck in september (paid KBB retail price... of course >.<) and don't want to have to rebuild the transmission. I've had a lot of luck with forums in the past and hope to get some help.
Thanks!!
Old Apr 9, 2012 | 06:12 PM
What brand governor pressure sensor and solenoid did you buy?
Welcome to DF!
Old Apr 9, 2012 | 10:26 PM
white7wolf's Avatar
white7wolf
Thanks for the welcome! I got them from the Lithia Dodge Dealer here so I'm assuming they were Mopar/Chrysler brand. I got a discount on them since I have family in the auto parts business here.
Old Apr 9, 2012 | 10:33 PM
Well, those should be good then.... Might wanna check the connector on the drivers side of the trans, we had a member here that had one that is in pretty bad shape.....
Old Apr 10, 2012 | 10:23 AM
zman17's Avatar
zman17
Retired Moderator - RIP
I'm curious as to what the code is. You can check in the manner also and see what comes up. https://dodgeforum.com/forum/2nd-gen...code-list.html
Old Apr 10, 2012 | 12:07 PM
white7wolf's Avatar
white7wolf
interesting, I didn't know the key trick would work on the newer ones. I know it works on my 94 Jeep. I'll go try the key trick at lunch.
Old Apr 10, 2012 | 12:11 PM
zman17's Avatar
zman17
It should work on your 99 ram. Doesn't work on 98's for some unknown reason.
Old Apr 10, 2012 | 01:54 PM
dodgeboy1979's Avatar
dodgeboy1979
Sometimes the wire harness going to the gov pressure solenoid will crack and a little bit of tranny fluid will get inside the wires and mess things up. This usually happens right at the connector inside the tranny
Old Apr 10, 2012 | 06:03 PM
white7wolf's Avatar
white7wolf
I forgot to grab the codes at lunch will try to remember when I leave work. Is the connector on the inside of the drain pan? or can I look at it just by crawling underneath the truck?
Old Apr 10, 2012 | 06:18 PM
Drivers side, kinda toward the back of the trans, on the outside. Check that first at any rate. Should be like an eight pin connector.
