Try an solve this temp problem
Old 04-10-2012, 02:38 PM
Lemunman's Avatar
Lemunman
Lemunman is offline
Default Try an solve this temp problem
Dodge ram 1996 5.2 318 1500
Okay I have a coolent temp guage problem it reads 220 steady after new napa sensor and failsafe 180* tstat I tried burpin her for an hour no luck. It goes to 220 like that's where it's supposed to be or something which I know it's not
Any of these cause This probem
Failsafe stat garbage already?
180 efan?
Underdrive pulleys for alt crank and water pump?
Or a bad new gauge sensor(one wire)
Old 04-10-2012, 02:40 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,198 Likes on 2,950 Posts
Check the connection at the gauge. Also, did you use any teflon tape, or thread sealant on the sensor? It want's to ground thru the threads to the manifold, if you insulate it there, you will get an erroneous reading.
Old 04-10-2012, 02:47 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
I'd lose the fail safe T-stat. And use a 195 stock temp stat . And check it before install.
Old 04-10-2012, 03:05 PM
safrantz's Avatar
safrantz
safrantz is offline
Describe exactly how you burped the system? I read about people jacking up their truck in a garage. I say if you can find somewhere close, drive it up an incredible incline...much easier.
Old 04-10-2012, 03:35 PM
Ham Bone's Avatar
Ham Bone
Ham Bone is offline
I had an air pocket right below the thermostat wouldn't get out until the the temp got to just below the red line. Took like 5 burps too.
Unlikely if you haven't drained the block but you never know
Old 04-10-2012, 04:36 PM
Lemunman's Avatar
Lemunman
Lemunman is offline
Hey you: I did use Teflon tape
Zman17: I ordered a 180 superstant because of my SCT tunner
Safrantz: I burped it by jacking up the passant side and having a friend hold the truck at about 2000 rpms every now and then with the cap off and me squeezing the hose's fr about an hour
Ham bone: I didn't drain ye block this time
Also it goes to 220 relatively quick before my efan even comes on which was set at 180 from before
Old 04-10-2012, 04:43 PM
HeyYou is offline
Lose the teflon tape on the sensor. They are pipe threads, so, just tighten it down, and it won't leak.
Temp sensor for your fan is in the upper hose? Yeah, the gauge is gonna get up to temp before the sensor sees it then. Once the stat opens, the fans should kick on. (if the coolant is hot enough...... some may cool enough initially before it gets to the sensor.)
Old 04-10-2012, 04:56 PM
Lemunman's Avatar
Lemunman
Lemunman is offline
I put the sensor in between radiator fins that what was instructed by flex a lite
Recently the fan comes on first before it hits 220 but it hits 220 like its almost supposed factory , which i know its not...I will clean off the threads and stick it back in with updates
I will put on the new stant cap as well see if she changes if not I guess I will put in the tsta also With a flush . Still accepting ideas
Old 04-10-2012, 05:02 PM
zman17's Avatar
zman17
zman17 is offline
OK no problem. I never would have suggested the 195 had I KNOWN about the SCT. Do some sig and profile editing. Hope you get the prob figured out.
Old 04-10-2012, 05:07 PM
Lemunman's Avatar
Lemunman
Lemunman is offline
Zman yeah I'm still trying to figure how to do that editing stuff cause I got a pretty impressive ride but I lack the know how to show it off
Quick Reply: Try an solve this temp problem
