Starting issue- hopefully can be solved
Old Apr 18, 2012 | 05:30 PM
  #21
Same part, 94 to 96. See if they have one available for a newer truck.
Old Apr 18, 2012 | 05:56 PM
  #22
Matt Nickerson's Avatar
Matt Nickerson
Originally Posted by Uncle Bannerman
Finally got the computer to flash a code at me and I might have a lead! It flashed 54, which the manual says is a camshaft position sensor. I know that's supposed to be under the distributor cap, but when I called the auto parts store, they told me that they don't sell them for my truck (1995). Is it part of the distributor and cannot be purchased separately or a dealer part? Or does it exist at all? Any thoughts would be appreciated!
It's a separate part and you can get it at the auto parts store. May have to ask for it under something more along the lines of a distributor pickup or ignition pickup.
  #23
Wombat Ranger's Avatar
Wombat Ranger
Originally Posted by zman17
Is the bulb good? If you are doing it correctly, it should flash. At least for a 55 code.
Mine wont flash at all unless it has something more to say than 12 or 55.
Old Apr 18, 2012 | 06:36 PM
  #24
Uncle Bannerman's Avatar
Uncle Bannerman
Could it be called the pick-up coil? The picture on Autozone's website looks the same as the picture in the book.
Old Apr 18, 2012 | 07:24 PM
  #25
Matt Nickerson
Same thing...
Old Apr 18, 2012 | 07:26 PM
  #26
jswain's Avatar
jswain
Others with more knowledge will answer, but I believe that is your part.
Old Apr 18, 2012 | 08:28 PM
  #27
zman17's Avatar
zman17
Retired Moderator - RIP
+1 on it being called pickup coil.
Old Apr 19, 2012 | 03:51 PM
  #28
Arde's Avatar
Arde
I know I'm talking apples-oranges here, but I have a 2.9L Ford that had exactly the same symptoms. Would start right up when cold or when I let it sit for a while. Would crank over great but wouldn't start after being driven until I let it sit a while.
To make a long story short, the problem was resolved by changing out the el-cheapo Wal-Mart battery cables with some decent ones with the molded ends. This was about 3 years ago, and haven't had the problem since.
Just another thought.
Old Apr 22, 2012 | 07:30 PM
  #29
Uncle Bannerman
Default Update
So I changed out the pickup coil and that worked, but . . . I have a new problem now. I drove it home from work today and it just cut off in the parking lot. Checked fuel pressure, and it's fine. The truck will turn right back off after it cuts off, and run for a few seconds, then die again. It doesn't shake or sputter. Just turns off. No code either, though it may not have been driven long enough. I checked the IAC and it was pretty bad, so I replaced it. It seems to cut off when it idles down to its typical idle speed, about 700 RPM. I was told to try and take the MAP off and see if it will run in a closed loop. Any thoughts????????
Old Apr 22, 2012 | 07:38 PM
  #30
gdstock's Avatar
gdstock
Did you clean out the IAC port? And disconnect battery while changing IAC?
