My driveshaft departed from the truck
Old 04-18-2012, 09:31 AM
moss500berg's Avatar
moss500berg
moss500berg is offline
Angry My driveshaft departed from the truck
Driving down the highway last friday (three days after i got my truck back from getting the transmission done) doin about 80mph, then BAM! I hear the wonderful sound of a driveshaft beating the **** out of the underside of my truck, so i get over to the shoulder as quick as i can, sure enough my driveshaft was missing. It was laying in the grass about 100 feet back from where i stopped.
The U-joint was still in the driveshaft, but the end caps were missing that went in the pinion yoke, the bolts for the u-joint clamps were broken off inside the yoke, and the yoke itself was trashed.
Is there any special consideration i should take or procedure i should follow when removing the pinion yoke?
Old 04-18-2012, 10:30 AM
Svehnd's Avatar
Svehnd
Svehnd is offline
I'd be going back to the place that did your tranny and having them fix it. They either left the bolts loose and the u-joint beat the hell out of the straps which snapped the bolts. Or else they over torqued the bolts.
Either way it was their screw up so they should be doing the fixing.
Old 04-18-2012, 10:46 AM
Pronk's Avatar
Pronk
Pronk is offline
Yeah sounds like they messed something up when re-installing your drive-shaft/u-joint
Or maybe your truck just has too much torque and the drive-shaft just couldn't handle it
Old 04-18-2012, 10:47 AM
SilverSS's Avatar
SilverSS
SilverSS is offline
+1 Make them pay to have it towed back there and check underneath to make sure there's no other damage. If there is they should have to fix that also.
Old 04-18-2012, 11:05 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,390 Likes on 3,130 Posts
Another vote for having a chat with the trans shop...... They are the ones that goofed. Probably put those guys in with an impact....
Old 04-18-2012, 11:40 AM
moss500berg
That would be fine and dandy except i put the trans in by myself with a friend.
Ive already got a driveshaft in the works, i just need to know about taking the pinion yoke out. Do i need to pull the spiders out and everything or can i just undo the nut on the yoke and pull it out without cracking the rearend open?
Old 04-18-2012, 11:44 AM
HeyYou is offline
Ooops.
Old 04-18-2012, 11:46 AM
moss500berg
Old 04-18-2012, 11:47 AM
chadhager03's Avatar
chadhager03
chadhager03 is offline
I had mine rebuilt by the shop and the same thing happened to me, they made me replace the driveshaft and would not reimburse me for the tow
Old 04-18-2012, 12:59 PM
gdstock's Avatar
gdstock
gdstock is offline
I would replace the yoke..doesn't look good!
Glad no one was hurt!
Quick Reply: My driveshaft departed from the truck
