Broken brake bleeder screw
Old Apr 29, 2012 | 09:43 AM
99ram360sport's Avatar
99ram360sport
Default Broken brake bleeder screw
I have a 1999 ram 1500 4x4 with the 5.9 and the other day I was looking under the truck and noticed the passengers side rear brake bleeder screw was broken off flush and only the threads were left. Is there any way to get it out or do I Have to replace the part it goes in?
Old Apr 29, 2012 | 09:55 AM
Since it already has a hole in it... you could try an easy out. DROWN it with chems first though...... aside from that, replacing it really isn't that bad. If your rear brakes are working good though, and you don't suspect air in the lines, don't worry about it until it becomes necessary.
Old Apr 29, 2012 | 10:31 AM
99ram360sport
Thanks hey you. My back brakes don't work very well but I suspect it is because there out of adjustment. Hopefully it's not because of air in the lines.
Old Apr 29, 2012 | 11:47 AM
Adjust 'em up, and see if it helps. Rear brake adjustment controls pedal height for the most part. (the point in pedal travel where the brakes actually start to engage.)
Old Apr 29, 2012 | 12:30 PM
zman17's Avatar
zman17
Retired Moderator - RIP
+1, and when that time comes you can do the WC upgrade mod, if you care to.
Old Apr 29, 2012 | 04:49 PM
99ram360sport
It looks like tomorrow I will be ordering new rotors,pads,drums,rear shoes and both rear wheel cylinders. What is the wheel cylinder upgrade zman is it to a 2500 wheel cylinder or something?
Old Apr 29, 2012 | 06:45 PM
Pronk's Avatar
Pronk
The upgrade is actually to a mid 90's Chevy 1 ton wheel cylinder, it is a direct swap but has a little more braking power. There's a few threads on here about it if you want to look into it some more.
Old Apr 29, 2012 | 07:43 PM
99ram360sport
Thanks pronk. I will take a look into that.
Old Apr 30, 2012 | 09:56 AM
zman17's Avatar
zman17
FAQ/DIY section has one in the "old links" link. https://dodgeforum.com/forum/2nd-gen...p-upgrade.html
