Look at the pan if it is square with a corner cut off it is a a500 or square with a bulge on the corner it is a a518
Originally Posted by A_POLVADO
iVE SEEN SOME 318S WITH A 42RE IN THEM NOT MANY BUT SHOULD BE THE DACCO 787 SORRY THAT IS THE ONLY PART NUMBER I KNOW i WORK AT CENTRAL TEXAS TRANSMISSION PARTS AND THAT IS OUR VENDOR
sorry about the caps im not yelling at you lol
Not a problem i will definately take a look its at work right now on base. Im pretty sure its bulged where the magnet sits dont quote me though.
What do you mean shaft diameter ? You talking about the input shaft if so the finding out that it is a a518 will answer that? If it is a a518 there are truly 2 stock option a 90 degree 5.2 convertor or a 90 degree 5.9 convertor which you can just use the 5.9 convertor they are basically the same.
Get a build sheet from chrysler. You can request it via email, (link in FAQ section for that.) or, give your vin to the dealer, and they should be able to print it off for you.
