Valve covers
Old May 9, 2012 | 01:33 PM
mccart's Avatar
mccart
Default Valve covers
Im getting a .512 lift cam and .515 valve springs. Will I have to get taller vale covers?
Old May 9, 2012 | 03:18 PM
gdstock's Avatar
gdstock
Don't know. That are you putting them on?
Old May 9, 2012 | 05:02 PM
A_POLVADO's Avatar
A_POLVADO
What rockers are you using you should be fine if you stick with stock configuration
Old May 9, 2012 | 05:05 PM
.003 clearance before coil bind? That would make me nervous......
Old May 9, 2012 | 05:16 PM
Wombat Ranger's Avatar
Wombat Ranger
How are valvesprings rated? Do they bind at .515 or are they safe for use with up to .515?
Old May 9, 2012 | 05:17 PM
I think they hit coil bind at the rated value. I would verify that with the manufacturer though... there might be some built in clearance there as well..... but, I would wanna make DAMN sure I had at LEAST .007 before hitting the upper limit. Some folks suggest even more.....
Old May 9, 2012 | 08:04 PM
mccart's Avatar
mccart
They're goin on a 318 magnum. Im using stock 1.6 rockers.
The heads I'm getting with the springs installed are the Odessa iron ram heads
Old May 9, 2012 | 10:51 PM
I would definitely have a chat with 'em, and see if there is any leeway in those numbers. If not, go for bigger springs..... better safe than spending more money on a bent pushrod, and whatever other carnage it causes.
