Brake upgrade-I hope
Old May 14, 2012 | 05:14 PM
charlie1935's Avatar
charlie1935
Default Brake upgrade-I hope
This past weekend I put 2500 calipers, ceramic pads, and new brake hoses on the 96 1500.
I didn't know it but the 1500 pads & 2500 pads had the same part #.
Old calipers were hanging up so it was time for replacement any way.
Next will be 3500 rear cylinders.
Old May 14, 2012 | 05:16 PM
You need to put some miles on that, and then give us your impression of just how much of an improvement it was.
Went with the light duty 2500 single piston calipers?
Old May 14, 2012 | 05:18 PM
charlie1935
Yes, the light duty ones. Haven't been out of town yet but it seems to be better, but with the old calipers screwing up it would be better any way.
Old May 14, 2012 | 05:19 PM
There is that.....
Old May 15, 2012 | 10:31 AM
charlie1935
So far it seems better.
Better response to changing pressure on the pedal.
I guess you call that easier to modulate the deceleration rate.
Old May 15, 2012 | 10:44 AM
gdstock's Avatar
gdstock
I installed the 1 ton cylinders on the back. Wish I knew how much better they performed, but ue to the fact that there were actuall parts MISSING from each rear wheel brake assembly, it would be difficult to determine. I do know that it will definitely stop on a dime and return change! Took a long time to stop previous to this but I dono't know how much (probably most) was attributed to waht seems top have been non functioning brakes on the rear.
Old Aug 16, 2012 | 08:35 AM
charlie1935
Just a follow up.
Around 2000 miles since brake upgrade.
Had to stop quick the other day for a light that had a short yellow.
Truck stops quite a bit quicker.
Had to ease up on brake pedal so I wouldn't stop before I got to the light.
Lots better than before.
Old Aug 16, 2012 | 10:14 AM
Ole Goat's Avatar
Ole Goat
Exclamation Brakes 94 Ram 1500 5.2
Does the heavier brake brake parts make a difference on stopping. Its starting to get scary driving this thing. I've just put new front calipers on and new pads along with rear shoes. They worked fine for awhile then started to lose braking power.
Could some one give me info on this.
Old Aug 16, 2012 | 10:21 AM
Sooper's Avatar
Sooper
I'm wondering about a stock rear axle with factory disc brakes. In the Gen II family, were there any axles with disc brakes that would work on an early Gen II like a '98?
I installed factory disc brakes from a 2003 Durango on my 1998 Durango. Switching from my stock drums to discs was an AMAZING upgrade and I was hoping to do something similar to my Ram.
If nothing else, I could mount and weld the flanges from my spare Durango axle to the Ram axle, and then mount rear caliper hardware from a Durango to the Ram's rear axle.
Old Aug 16, 2012 | 10:39 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
The only discs I know of came off the later Gen 2 2500's.
And those are rare.
