99 dodge v10 488- start up issues
Old May 24, 2012 | 10:36 PM
bell's Avatar
bell
Question 99 dodge v10 488- start up issues
1999 dodge ram v10, when starting up, often, fires right up and then shuts down. sometimesit will do that 2,3,4times before it will run then runs good. have noticed it sounds like timing isn't quite right when shutsdown. cleaned throttle body, replaced iac valve and tps plus,cam and crank position sensors. have checked all electrical connections under hood.could map sensor cause this issue ? seems short on power at 75 mph at 2000 rpm .
Old May 24, 2012 | 10:38 PM
Any codes? Also, need to check fuel pressure.
Welcome to DF.
Old May 24, 2012 | 11:45 PM
gdstock's Avatar
gdstock
+1 on checking fuel pressure. As engine begins to starve for fuel, it can seem like timing is off.
Old May 26, 2012 | 03:41 PM
bell's Avatar
bell
1999 dodge v10, checked fuel pressure is at 45 lbs , no codes showing did notice when engine is starting to die, given gas will stay running.recent rebuild on motor so everything on longblock is up to specs, mileage on truck is 100,000
Old May 26, 2012 | 05:33 PM
Did you disconnect the battery while changing sensors??
Old May 26, 2012 | 06:52 PM
bell's Avatar
bell
Question
1999 dodge v10, yes, battery was disconnected, guess, with age of sensors was time to update, manifold absolute pressure sensor=map sensor seems to be a main sensor, that adjust fuel mixture and timing,from what i read on dodge forum . so what you guys think ?
Old May 26, 2012 | 06:58 PM
Pull the front O2 sensor, and see if it runs any better. (physically remove it from the exhaust.)
Old May 26, 2012 | 08:06 PM
bell's Avatar
bell
1999 dodge v10, okay can do that, this one has 2 one on each side next to transmission, cats back by rearend.have noticed problem seems to be worse when engine is at normal operating temperature.these sensors connected to map?
Old May 26, 2012 | 10:57 PM
gdstock's Avatar
gdstock
Don't know about V10, but on V8 they go to PCM.
Have you gone to the FAQ/DIY section and download service manual?
Old May 26, 2012 | 11:01 PM
Put your truck info in your sig, and profile, that way, you don't have to type it out each time either.
