Finally Changing Main and Rod Bearings!
Old Jun 2, 2012 | 08:16 AM
dhvaughan's Avatar
dhvaughan
loosen the main cap bolts about 1/4 to 1/2 inch but don't remove the bolts. (so the bolts will catch the cap when it comes loose). use either a rubber hammer, or a block or wood and a steel hammer and smack the cap on the side or the face. start gentle and increase force a little at a time. use the wooden block and don't hit metal on metal.
MARK THE CAPS so you put them back in the same place, same orientation.
Old Jun 2, 2012 | 11:03 AM
Moochoff's Avatar
Moochoff
Caps are already marked, and that was the plan...
Ill reply back when I'm done!
Old Jun 2, 2012 | 11:28 AM
let us know how things turn out.
Old Jun 2, 2012 | 07:43 PM
Moochoff's Avatar
Moochoff
torque specs for rods? cant find them in the manual?
is it 85 for mains and 45 for rods if i remember seeing somewhere?
Old Jun 2, 2012 | 07:51 PM
Mains: 85 ft/lbs.
Rods: 45 ft/lbs.
Yep.
Old Jun 2, 2012 | 07:52 PM
dhvaughan's Avatar
dhvaughan
rod caps 45 ft lb.
main caps 85 ft lb.
i type too slow.
Old Jun 2, 2012 | 08:20 PM
Moochoff's Avatar
Moochoff
Ha ha thanks guys...
So i took the serpentine belt off to help roll the crank over- its still off at the moment..
I am about to torque the rods back down but the crank wont budge after i torqued the mains back down....? is that normal?
I did 40-65-85 ft lbs on the main to make sure they went on straight too
Old Jun 2, 2012 | 08:27 PM
No. It's not. You got something jammed up somewhere. Pull the mains, see what's up.
Did you get standard size bearings?
Old Jun 2, 2012 | 08:31 PM
Moochoff's Avatar
Moochoff
Originally Posted by Arde
Just wondering as I haven't been into the bottom end on my 360 yet, but is there some reason you can't just use a roll-out pin to remove and install the upper half of the mains?
Just an FYI, I used a small 1/8" flat head and bumped the bearings just enough to slide them out- then used a tiny pair of needle nose pliers and pulled on them around the bottom of the journals as I wiggled the crankshaft back and forth
Old Jun 2, 2012 | 08:33 PM
Moochoff's Avatar
Moochoff
Yep they said STD on them for standard I assumed?
I wonder if my rear seal got boogered up as I lined it back up... I tried to offset it so the ends weren't flush where the cap meets the block hoping for a better seal.
