Finally Changing Main and Rod Bearings!
Old Jun 2, 2012 | 08:49 PM
  #21
Moochoff's Avatar
Moochoff
Well I loosened the main bolts without dropping the caps and the crank started to move again.... I winder if I accidentally had my torque wrench set too high? Ill do some more investigating
Old Jun 2, 2012 | 08:56 PM
  #22
charlie1935's Avatar
charlie1935
Did you lube the inserts before putting them in?
Haven't done that in years but I used to use a 50/50 mix of STP & 30 weight oil or the white lithium grease.
Old Jun 2, 2012 | 09:23 PM
  #23
Moochoff's Avatar
Moochoff
I sprayed the bearings and journals with white lithium before re installing... I used a litle 10-30 on the rear seal to help it out... I just grabbed a little supper and am about to retorque and see what happens
Old Jun 2, 2012 | 09:36 PM
  #24
I would verify that the bearings are in correctly......
Old Jun 3, 2012 | 12:37 AM
  #25
Moochoff's Avatar
Moochoff
I somehow managed to kink up the rear seal like I thought... all my bearings were seated well
Put it back together and I still cant keep oil pressure over 10 psi at a warm idle...
Looks like I'll be switching to 20w-30 and see how long it will last
Old Jun 3, 2012 | 01:09 AM
  #26
gdstock's Avatar
gdstock
Did you use plastigauge to check bearing clearance? That is really the only way to get the torque correct on mains and rods. A couple of punds can make a diffenece here. It they are too tight on journals it will cause excessive wear.
Old Jun 3, 2012 | 01:54 AM
  #27
Wombat Ranger's Avatar
Wombat Ranger
Man that sucks having your hopes dashed against the rock in such a fashion as that.
I hope you figure it out.
Old Jun 3, 2012 | 03:22 AM
  #28
charlie1935
Are you going by the stock oil pressure gauge?
If so, hook up a manual gauge to check it.
Old Jun 3, 2012 | 04:24 AM
  #29
Moochoff's Avatar
Moochoff
I have been going off a mechanical gauge... The sending unit was the first thing I replaced, then oil pump, and now bearings...
I just wanted to see something positive so I ran to Walmart in the middle of the night and grabbed 5 quarts of 20w-50 and dumped it in... The pressure stays for longer but eventually drops to nothing after 10 minutes of operating temp.
I am out of ideas here...?
Old Jun 3, 2012 | 08:39 AM
  #30
dhvaughan's Avatar
dhvaughan
i hate to hear the bad news, i was rooting for you to get a better result.
what's your new oil pump? standard or high volume?
my only ideas would be try a high volume oil pump,
or redo the bearings again and use plastigage and oversize bearings to reduce clearances.
the majority of the oil journals are on the crank, along with some more on the cam. i'd think it would be a lot more critical to tighten the crank, before messing with the cam.
