Fixed Plenum Now Need to Replace Fuel Rail
Old Jun 2, 2012 | 09:38 PM
  #21
Is that the one I sent you??
Unfortunately, I didn't get it from a running engine......
Its plastic, so, might be able to melt a little into the hole, and seal it up. If you have any plastic models, melt a piece of the 'framing' that the parts come on into the hole.
Old Jun 2, 2012 | 09:39 PM
  #22
Either that, or drill it, tap it, and put a bolt into it, with some sealer.
Old Jun 2, 2012 | 10:02 PM
  #23
sbrodacz's Avatar
sbrodacz
It is. I know you did not get to test it. No biggie.
I was thinking of maybe taking a torch to tit and melting it but I do not know how thick it is and do not want to burn a hole in it. I think if I drilled a hole and put a bolt it in it was just crack it. The side is not very big. What about jb weld or something. There has to be something that I can coat it with and seal it? I remember there was a puddy you could buy at the hardware store. It was green with a gray middle. Once you mix the two it hardens in 20 minutes or so. It's used to seal pipes and stuff. I had used it to seal a leak in a fish tank once. I wonder if that would work..
At first I thought it was the fuel injector but you can clearly see it squirting out of the fuel rail.
Old Jun 2, 2012 | 10:27 PM
  #24
I would use a tiny drill bit, drill it out just a hair, and then try some of that putty, or JB Weld, or even muffler cement.....
Old Jun 2, 2012 | 10:34 PM
  #25
gdstock's Avatar
gdstock
Dorman shows a replacement for a 97.
Old Jun 2, 2012 | 10:54 PM
  #26
sbrodacz's Avatar
sbrodacz
I'll give that a shot. I need to find the hole first. I saw it was squirting out and left.
What?
Old Jun 2, 2012 | 11:49 PM
  #27
johnnyjaws98's Avatar
johnnyjaws98
your fuel release line cost like 6.00 bucks from auto zone live and learn
Old Jun 2, 2012 | 11:53 PM
  #28
sbrodacz's Avatar
sbrodacz
Not sure what your talking about. Its the end of the fuel line right above the last injector.
Old Jun 3, 2012 | 12:10 AM
  #29
gdstock's Avatar
gdstock
What?
Dorman Automotive products. Available on line or your local auto parts store. I would be cautious patching plastic. If it leaks, your truck could burn down.
Old Jun 3, 2012 | 01:29 AM
  #30
Wombat Ranger's Avatar
Wombat Ranger
If you are gonna keep the truck a while convert to the other type of line and metal fuel rails...
