Keggor mod question
Old Jun 9, 2012 | 05:18 PM
  #31
bwdakrt's Avatar
bwdakrt
Originally Posted by 2x1972
I already fixed mine, using shorter bolts, but the way you said it makes it sound like you have facts to back it up. I am just curious. At the variations of temperature that these engines see, I really have a hard time believing that the difference in metal cooling time would be a problem.
Only time will tell. Good luck!
Old Jun 9, 2012 | 05:28 PM
  #32
Wombat Ranger's Avatar
Wombat Ranger
More likely in my opinion the failure (if it does happen again) would be because (as Zman has pointed out in the past) some of the bolts on the plate might be spaced a bit too far apart, and since steel flexes more than aluminum, it might not be able to keep enough pressure on the gasket, letting it blow out. But, as you said, only time will tell.
Old Jun 9, 2012 | 09:19 PM
  #33
KxRideRon125's Avatar
KxRideRon125
well i guess ill be the guinea pig on this one i don't have a lot of money so if shorter bolts are gonna hold up a yr or 2 i'm gonna go that route
Old Jun 9, 2012 | 09:26 PM
  #34
stewie01's Avatar
stewie01
Makes you wonder just how much the stock plate with stock bolts actually flexes under normal use and temperature.
Old Jun 9, 2012 | 09:33 PM
  #35
I did the math on the difference in expansion rates...... and the amount of movement was TINY. Couple thousandths of an inch at most. The bolts being too long, and not allowing proper clamping force on the gasket has a much higher likelihood of being the real culprit here.
Old Jun 10, 2012 | 12:22 AM
  #36
1999blkdakrt's Avatar
1999blkdakrt
Who says the bolts are too long? Maybe the bolt holes are too shallow!!!
Old Jun 10, 2012 | 01:54 AM
  #37
Wombat Ranger
Makes way more sense to me too. If my shortened bolted stock plated gasket fails, you all will be the first to know.
Old Jun 10, 2012 | 10:03 AM
  #38
THAT'S IT!!!!!
Old Jun 10, 2012 | 10:35 AM
  #39
KxRideRon125
hahaha
Old Jun 10, 2012 | 06:03 PM
  #40
Adobedude's Avatar
Adobedude
Glass is half empty....especially now.
