Top 10 design issues with Magnum engine trucks
Old Jun 8, 2012 | 03:29 PM
  #31
stewie01's Avatar
stewie01
8,000.5lbs.
Old Jun 8, 2012 | 05:10 PM
  #32
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Originally Posted by 2x1972
5200 Lbs for my 2500 4x4, so none of you 2wd 1500's are even near 5000... I am getting 13.3ish with 35's, stock gears and a 5.9. That is not terrible. I haven't had most of the rest of the problems either.
My registration says 5500 empty.
Old Jun 8, 2012 | 05:35 PM
  #33
stewie01's Avatar
stewie01
This is turning into a "mine's bigger" contest.
Old Jun 8, 2012 | 05:50 PM
  #34
Ramcountryboy's Avatar
Ramcountryboy
I hauled some stuff to the dump a month ago, and empty the scale said 5900, i did have some tools and usual stuff, i was pretty surprised... but then a again on my there i did stop for coffee
Old Jun 8, 2012 | 06:29 PM
  #35
lastrights's Avatar
lastrights
Don't for get the exhaust system , crappy y pipe and clogged cats
Also rusty wheel wells
Also ping issues lol
Old Jun 9, 2012 | 01:55 AM
  #36
RageGuy's Avatar
RageGuy
So many complaints / issues, SO I am curious...Why do you all Own your truck if so much sucks with them....?
Old Jun 9, 2012 | 02:16 AM
  #37
SilverSS's Avatar
SilverSS
My 98 2wd qc with a little bit of stuff in the toolbox and 3/4 tank of fuel weighed 5640 leaving the landfill with my dog and kids so subtract our weight and the truck was 5260. I usually avg 13.5 MPG with 3.55's but got a hair over 14 cruising down i75 @ 75 MPH last week . Was 11-12 when I had 33" mt's.
Old Jun 9, 2012 | 08:29 AM
  #38
rumble_truck's Avatar
rumble_truck
5450lbs according to scrap yard scales, reg cab sb 4x4 w/ 35's (or 5250, its a blurr, moneys on the 5450 though)
Why has no body mention the distributor is in the rear? like to kick the engineer who had that idea square in the man beans.
Old Jun 9, 2012 | 09:00 AM
  #39
stewie01's Avatar
stewie01
Good catch! Dodge shoulda pulled a Ford and put the dizzy in the front of the motor!
Old Jun 9, 2012 | 10:21 AM
  #40
Depends on what you have in mind with the dizzy..... if you off road a lot, and go thru deep water, behind the manifold is the most protected spot. In front of the manifold, and the dist is in serious danger of getting wet..... at which point, the engine stops running. In the middle of the creek, that would be a problem.
