Top 10 design issues with Magnum engine trucks
#42
#44
And I really don't get all the whining that goes on about the distrubutor location. It's not as convenient as the front, but I changed the cap and rotor in about 8 minutes. You'd spend twice that removing plastic from anything newer...
#48
I think the driver's seat belongs on the list. The outer edge should have had stiffer foam and a sturdier fabric.
The only real problem with disty at the back is the lack of room between engine and firewall. This also noticed when checking/changing crank sensor! I mean it's not like they could not have shortend the fan shroud an inch or two and moved ecerything forwad slightly!
#49
