Replacing Front Brakes
The weekend, I am planing on replacing my front brakes. I am doing pads, rotors, and calipers.
Based on research on this site, I am going with 2500 light duty (7500 lb) calipers, which require the pads for a 2500. Rotors for a 1500, of course (5 lug).
I have done brake pads before, and they are pretty easy. Any special tricks for these trucks?
-The rotors just slide off, like a regular car, is that correct?
-Removing the calipers is my biggest worry. I went through the 1996 service manual, downloaded from the site, and it seems that you just unbolt the 2 bolts, like you normally would for removing the pads.
The only additional step seems to be unbolting the brake line. This just unscrews and hangs, correct? I assume that brake fluid will be leaking from the line, should I just let it drip into a drain pan?
Any suggestions would be greatly appreciated!
Trending Topics
