Plenum - my turn
Old Jun 26, 2012 | 06:58 PM
  #21
dhvaughan's Avatar
dhvaughan
don't kick yourself. sometimes you just have to throw in the towel and take it to a pro. look on the bright side - its fixed and you learned a lot.
Old Jun 26, 2012 | 07:28 PM
  #22
Originally Posted by mcweaver
after getting everything back together, i had a water leak, my truck wouldn't idle, truck played games shifting from 1-2, 2-3 and the wonderful people at Autozone told me I had a vacuum issue. So after taking everything back apart and looking at things again and thinking I fixed the problem, well I didn't. So frustrated I took it to our garage very discouraged and embarassed. So the no idle, I forgot to plug in the IAC, water leak was a wore out spring clamp on the upper radiator hose, the no shifting the TV cable was just too tight and caught on something. Anyhow, even though this makes me look a little more like an idiot I wanted to post this update because I'm guessing somewhere down the line someone else will have one of these problems.
If this is your first time digging into a motor that deep, I think ya done good.
Old Jun 26, 2012 | 07:38 PM
  #23
john165's Avatar
john165
Hey mcweaver, how did you go about removing the egr tube? After you break the fitting loose was there enough flex or slack in the tube to put it to the side or did you have to take the other end of the tube loose where it mounts to the downpipe on the passenger side to remove the tube completely?
Old Jun 26, 2012 | 07:41 PM
  #24
His is a 98. No EGR. should be able to just sorta push it back a bit, to keep it out of the way though.
Old Jun 26, 2012 | 07:49 PM
  #25
john165's Avatar
john165
Thanks man. I was reading the sticky about plenum thread and i dont remember seeing anyone posting about that except one poster said not to take the tube loose at the downpipe because those two little bolts always break off.
I had no idea there wasnt no egr lol. Thanks again.
