Ac isn't work for some reason. Checked the pressure and its in the red but only because it is not even cycling. Relay clicks so sounds like its getting power? any one know what could be wrong? i dont really know where to start. tested for power from the two wires going in to the clutch and have no power there...
Yeah 120 is way to high for the low side which is where you should be charging and testing for pressure. It should be around 40-45 psi on the low side.
With the compressor not running, my guess is, high and low side have equalized pressure. You only get an accurate low-side reading while the compressor is actually running.
