Sonova B**** Wont stay running.
Old Jul 8, 2012 | 11:46 AM
  #21
TGoodwin's Avatar
TGoodwin
The thing only holds 5 quarts! Well mine does anyway. Holy crap.. What was your oil pressure running at? I have not smoked weed for many years BUT forgetting to add oil after an oil change is just the kind of reason I don't anymore.
My GF has run her Isuzu rodeo out of oil twice that I know of. I usually check the oil on hers when the car is there and I am out doing stuff to my truck. She checks that oil weekly now. The motor seems to run OK but I don't think it was dry...Just not showing on the stick.
Hope you get it sorted out.
Old Jul 8, 2012 | 12:01 PM
  #22
Going thru that volume of oil, my bet is the plenum is badly blown. It won't necessarily blow smoke either. (mine had a high rate of oil consumption, but, I never saw any blue smoke, and no puddles on the driveway either....)
Will it stay running if you step on the gas a bit?
Tune up is a good plan.
Old Jul 8, 2012 | 12:10 PM
  #23
joekool4's Avatar
joekool4
So turns out I have no fuel pressure today.
Old Jul 8, 2012 | 12:11 PM
  #24
Cycle the key a couple times, and see if pressure doesn't come up. You can get a gauge for fairly cheap at the local parts store..... they want a big pile of cash to rent one.. but, you get it back when you return the gauge.
Old Jul 8, 2012 | 12:21 PM
  #25
joekool4's Avatar
joekool4
Absolutely nothing, no hiss or anything. Also not hearing the pump kick on when I turn the key
Old Jul 8, 2012 | 12:26 PM
  #26
Swap the fuel pump, and horn relays.
Do you hear the relay click when you turn the key on? (might grab a friend, and just stick your finger on the correct relay, and test....)
Old Jul 8, 2012 | 12:34 PM
  #27
joekool4's Avatar
joekool4
It will turn over with starter fluid rev to where its suppose to then die.
Old Jul 8, 2012 | 12:35 PM
  #28
merc225hp's Avatar
merc225hp
You can also try hitting the bottom of the gas tank where the pump is. Things are looking up.
Old Jul 8, 2012 | 12:41 PM
  #29
joekool4's Avatar
joekool4
I hear and can feel the relay click. Got my mom to do turn the key. Listened for the pump by the filler and crawled under the truck. I think I may have found the problem! well one of them at least.
Old Jul 8, 2012 | 12:53 PM
  #30
joekool4's Avatar
joekool4
They definately are, cause any actual engine work, I could probably do if i hadd all the tools, but i dont. BUT iI'm pretty sure i can change a fuel pump. Dont know if i want to lift the bed or drop the tank yet... If i hit the bottom of the tank will it act like a frozen starter and work for a little bit? what would i be looking for? I've also been trying to diagnose the plenum, Its the original steel plate, so I doubt its been fixed. I bought the aluminum plate (was having a misfire on #8 that just went away, hasnt happened in over 8 months). But theres no pooling of oil on the plate, pretty sure thats where the oil went. I'll have to do that and straight pipe it with the jegs Y pipe.
