Trans kicking down too many gears...
When I am accelerating the tranny seems like it kicks down at least two gears and makes the engine over rev.....when pulling my trailer up a hill if you give it too much gas it just about red lines the engine and you gotta let off the gas.
Any ideas?
2001 Dodge Ram 1500 Auto with 355's
Any ideas?
I tow in with it off......this happens pulling or just driving....has always done this. When u kick into passing gear it drops more than one gear down and makes the engine over rev.
Under geared or course with 3:55's . But you have an under powered problem. Which leads to clogging cat, which leads to blown plenum. Have you read the plenum sticky? Probably not is my guess.
Thanks for your help.............smart guy.
Trending Topics
Factory adjustment in this thread as a place to start and zero it out , https://dodgeforum.com/forum/2nd-gen...-in-trans.html
Then you can F with it after, using the info in this link. http://www.bionicdodge.com/Download/...Adjustment.pdf
