Valve Timing Questions
Old Sep 2, 2012 | 01:30 PM
  #141
MeanMagnum99's Avatar
MeanMagnum99
PCMScan, and a host of others..... I think there is a site out on the web, that has links, and reviews, on a selection of them.
There are some purchasable version that will also let you WRITE to the PCM..... I.E. do your own tuning.
I'm on that website, but which one should I get that will allow me to read fuel sync?
Old Sep 2, 2012 | 01:36 PM
  #142
MeanMagnum99
Is this what I need?
http://www.palmerperformance.com/sto...products_id=55
Old Sep 2, 2012 | 01:43 PM
  #143
Adobedude's Avatar
Adobedude
Originally Posted by MeanMagnum99
I believe the dealership uses the DRB 3 scan scan tool. I just read on bionic dodge that with a higher lift, especially one with advanced timing already ground into it that setting it +4 to +12 helps. Im ordering my SCT Stage 1 Custom Tuning tuner on the 14th. From there I'm sure I can fine tune things.
On the Dakota with a 258/252 @.50" 576/584 @ 4º cam I'm still on the stock PCM tuned with a email tunes w/ an SCT by Chris at PIE and it's forced into open loop all the time, we are still trying to getit to idle but the WOT AF is 12.8 to 13.1
I set my sync a +4
Next year I'll either be carbed or running a FAST XFI I have sitting on a shelf...Any tuning done with a lap top is going to be a huge learning curve and SCT is one of the hardest from what I understand.
Old Sep 2, 2012 | 01:47 PM
  #144
Adobedude's Avatar
Adobedude
I've never read of any software out there that will allow you to set Fuel Sync other than a a Snapon 2500 (or EQ) or a DRB, so make sure you actually can before you spend any coin on it.
Old Sep 2, 2012 | 01:49 PM
  #145
MeanMagnum99
I set my sync a +4
Well I guess I'm just going to buy this product and set my fuel syn myself and see what works for me. Sean with Hemifever is doing my tunes for me. He told me he would start off with a pre installed tune based off the info I give him then send me tunes via email to get it running good.
Old Sep 2, 2012 | 01:52 PM
  #146
MeanMagnum99
Looks like I'm making some phone calls then.
Old Sep 2, 2012 | 02:56 PM
  #147
gdstock's Avatar
gdstock
Snap On 2500 series scanner is pretty reasonable. They have ben discontinued by Snap On so they can be found on ebay pretty cheap. Since Snap On does not supprt it any longer, I have come to learn that Texassizedeals on ebay (he's in Houston) has been very helpful to me on this. Has the components such as modules, keys etc.
And it allows me to set fuel sync, and is not limited to one vehicle.
Old Sep 2, 2012 | 03:19 PM
  #148
Adobedude's Avatar
Adobedude
Gotta get the right cartriges and Key, I borrowed one locally.
Old Sep 2, 2012 | 03:23 PM
  #149
gdstock's Avatar
gdstock
Yep. Cartridge is Ford-GM-Chrysler (through 1999 for mine) and the Personality Key 13. I use same cart with different key for other vehicles I have (or family members) and the nappropriate cartridge for Yota and other vechicles. Have accumlated a number of cartridges and other connectors for non OBD compliant vehicles. Darn thing is great!
Old Sep 2, 2012 | 03:36 PM
  #150
MeanMagnum99
If only I had the extra money to afford all that. Looks I'm keeping my appointment with stealership.
