Valve Timing Questions
Old Aug 29, 2012 | 04:15 PM
  #121
gdstock's Avatar
gdstock
You are looking at a differecne of 0.02", or about the thickness of a piece pf paper. They will be a little tighter if anything. Can't see why they would not work fine.
Lap the valves!
Old Aug 29, 2012 | 05:05 PM
  #122
Hahns5.2's Avatar
Hahns5.2
Lap the valves!
.02" is a lot more than a sheet of paper.
Hipotek is good people from all accounts, if Richard says they'll work I'm sure they will.
Old Aug 30, 2012 | 06:44 AM
  #123
MeanMagnum99's Avatar
MeanMagnum99
Yeah Richard seems to be a great guy. He said they would work just like the MP springs so I took his word for it. I also told him all the mods on my truck and what future mods will be done and he was able to get me a custom ground cam picked outa and some Johnson Hy-Lift lifters. He also said was able to work out a better price than what's listed on his site. IMO that's some top notch customer service and he's got my future busines.
Old Aug 30, 2012 | 12:47 PM
  #124
gdstock's Avatar
gdstock
OK. I stand corrected. Photopaper (which I consume huge quantities) is thicker, but std 20# paper is about 0.006".
But it should still work...
Old Aug 30, 2012 | 11:21 PM
  #125
MeanMagnum99
I looked at all the different sites that carry the MP springs and most of them have slight differences in sizes so I guess it depends on who's measuring it. From all my research and from Rich confirming that they worked I couldn't turn down his springs especially for the price.. I'm ordering his 210xp cam with a 110 lsa which he said is a very popular cam and is the same grind as the KRC 210x cam. Then I'm also getting the Johnson Hy-lift lifters he has. I'm ordering the cam and lifters tomorrow and will have my SCT stage 1 tuner from Hemi Fever in 2 weeks. I'm in the Army so I only get paid twice a month so I do what I can with what little I have after bills.
Old Aug 31, 2012 | 04:44 PM
  #126
MeanMagnum99
Ok fellas, all the parts are ordered, but I just thought of something. When I fork out $100 for the dealer to set my fuel sync, what should I have them set it at since I have a cam that has way more lift and duration than stock? +4 or +6?
Old Sep 1, 2012 | 08:27 AM
  #127
I would be real tempted, instead of paying the dealer to set sync, spend a bit more, and buy a scanner that will read it..... then, experiment...... If you can see what the value is, you can wiggle it around, and see what works best for you.
Old Sep 1, 2012 | 09:57 AM
  #128
MeanMagnum99
I wish that was an option, but I have dropped most of my money into building the top end up on this truck and lots of other upgrades as well. I read that if the dealer uses the DRB scan tool to have them set it at +8 to +12 and if they use the snap-on mt2500 to set it at +4 to +6. I just need it to be usable until I get my SCT tuner from Sean at Hemifever next week.
Old Sep 1, 2012 | 12:15 PM
  #129
If your cam is installed straight up, and doesn't have any 'built in' advance, I do believe you want sync at zero......
Old Sep 1, 2012 | 12:19 PM
  #130
merc225hp's Avatar
merc225hp
^^^ +1 zero it is.
