Valve Timing Questions
Old Jul 10, 2012 | 02:01 PM
  #21
MeanMagnum99's Avatar
MeanMagnum99
Considering your engine spends most of it's life in the lower RPM range... yeah. I would have to say advancing a bit would be most beneficial. Of course, if you go with a tuner, make sure whoever you chat with is AWARE that you have altered cam timing.
Fandango good sir! Well I will go with advancing it and when I get the SCT tuner here in the near future I will be sure to let them know. Since the crank is advanced 4* the cam will be actually 2* advanced over stock?
Old Jul 10, 2012 | 02:13 PM
  #22
That depends on your timing set, and what you are referring to as "crank advance". According to popular theory, if the timing set says +4, that is what you should actually get on your cam timing. I think.
Old Jul 10, 2012 | 03:56 PM
  #23
MeanMagnum99
Just wondering which timing set would be better, the mopar performance double roller or the comp cams double roller set? I've heard good things about both, but unsure which would hold up better.
The comp cams is: http://www.compperformancegroupstore..._Code=LATiming
Mopar Performance:
http://www.summitracing.com/parts/DCC-5249267/
Old Jul 10, 2012 | 05:14 PM
  #24
aim4squirrels's Avatar
aim4squirrels
If you can find a JP performance set, that's the one I'd use. Actually, I did model number 5985. It's tight as a ****, you might have to finger sand the inside of it to make a bit of room on the crank snout, but it's so damn tight that even with the natural stretch, it'll stay tight.
If not the JP, then either would be fine, but I'd run the Chain Tensioner from Mopar Performance
Old Jul 11, 2012 | 08:16 AM
  #25
MeanMagnum99
Ok great info! So if I use the JP set I won't need the tensioner correct? But if I use the other chain sets and use the tensioner it says to use the tensioner instead of the cam thrust washer. So I guess I would put the tensioner on without the OEM thrust washer on the end of the camshaft then cam gear then bolt it down? Oh! I almost forgot, will advancing my cam timing be harmful with the 1.7 rockers I'm also installing?
Old Jul 11, 2012 | 03:52 PM
  #26
MeanMagnum99
Well I bought that set you recommended. So you said I shouldn't need the tensioner with this set correct? Now with advancing the cam timing 4* will my 1.7 roller rockers be ok?
Old Jul 11, 2012 | 04:07 PM
  #27
Should be fine.
Old Jul 11, 2012 | 07:35 PM
  #28
MeanMagnum99
Should be fine.
Alrighty then. Thanks for all the help everyone! It's much appreciated!
Old Jul 13, 2012 | 10:45 AM
  #29
billcart's Avatar
billcart
Hijacking here but I was wondering if anyone has done this chain set:
http://www.hughesengines.com/Index/p...1&partid=23310
Old Jul 13, 2012 | 10:55 AM
  #30
There are less expensive alternatives... Cloyes, Comp Cams, etc. Check on Jegs, and Summit. Also, don't forget to check with your local parts stores as well.
