no power up hills
Old Jul 11, 2012 | 10:06 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Originally Posted by Ram3602500
Plug 1 looks fine but its a Autolite platinum Im gonna get copper plugs and pull out the O2 sensor and see
That's your problem. These trucks do not like platinum plugs.
Old Jul 12, 2012 | 10:08 AM
Ram3602500's Avatar
Ram3602500
So I put the copper plugs in this morning I'm gonna change the cat later on during the evening but after I changed the plugs I went to clear the codes and the code came out misfire cylinder 7 so Im assuming it was those crappy plugs I'm gonna change the cat regardless so let you guys know what happens
Old Jul 12, 2012 | 10:15 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Did you properly gap the plugs and also follow the wire routing procedure? If the plug wires aren't routed properly, cross-firing can occur, which will produce a misfire.
Old Jul 12, 2012 | 11:16 AM
jondakotaguy's Avatar
jondakotaguy
Out side of all that; when your going up the hill under light throttle increase does your truck drop down a gear or do you have to press the gas into passing gear?
I had the problem and I replaced my map sensor with a Delphi and it now drops down a gear under light throttle acceleration or when ever the truck starts to loose speed (Going up a hill and no throttle increase) that's how it should act.
if i'm making my explanation clear enough.
Also when you make a turn around 10-20 depending on the speed the truck shoudl drop down gear.. if MAP is not sending proper signal and/or reading properly (this is typcially the case- not reading properly ) it wont and you have to mash the gas to getmoving.
Also plenum and basic tune up.
Old Jul 12, 2012 | 12:32 PM
Ram3602500's Avatar
Ram3602500
Well my truck down shifts by itself but it stays the same speed even if I give it gas it struggles to get spped if I mash the gas it will probably stay the same but wont go any faster
Old Jul 12, 2012 | 12:44 PM
Check your cat. And the plenum.
Old Jul 12, 2012 | 09:57 PM
Ram3602500's Avatar
Ram3602500
Truck runs great alot of power! The cat was really clogged it was all broken and looks like the center was melted or something but whatever the trucks great and Im happy. Thank you guys for all your help I really appreciate it
Old Jul 12, 2012 | 10:54 PM
TGoodwin's Avatar
TGoodwin
Thank you but my truck does have a weird sound when it first starts like a loss heat sheild but thers not I check it sounded like it was coming from the cat when I checked and I got a code this morning for cylinder 1 misfire
Mine was like that...sounded like a tin can inside the cat at idle and a certain RPM.
