What else while I'm in there
Old Jul 18, 2012 | 05:28 PM
  #31
dlyter09's Avatar
dlyter09
Well after you do the compression test see how everything comes back. Ive never run anything besides 10-40 in my Rams and Ive never had an issue. It could be worth a shot to switch and see if that helps at all.
Old Jul 18, 2012 | 05:40 PM
  #32
Lemunman's Avatar
Lemunman
DLyter I will go buy some more see if that thickens it up .. I think that zinc additive broke up alot of sludge I haven't replaced the oil pump or pick up in about 8 yers
Old Jul 18, 2012 | 06:23 PM
  #33
dlyter09's Avatar
dlyter09
It could probably use a good cleaning then. Just some ideas for you to try that arent gonna kill your wallet
Old Jul 18, 2012 | 06:42 PM
  #34
gdstock's Avatar
gdstock
Originally Posted by Lemunman
Fingers crossed then .. Do you thing the temp gauge being 200 instead of 180 an the oil fluctuating a little bit from 20 to 40 could be all one problem? Also my gas guage is always on E haha non related
200 is not an issue.....is this while idling or driving down the highway? If parked and idle, you will not stay around 180 very long.
Old Jul 18, 2012 | 07:23 PM
  #35
Lemunman's Avatar
Lemunman
It goes to 180 efan kicks on then slowly climbs to 200 and stays there at idle and a very little above diring driving.i noticed when I was towing the temp actually went down to 180
Old Jul 18, 2012 | 10:05 PM
  #36
Wonder if your radiator still has a blockage somewhere.....
Old Jul 18, 2012 | 11:29 PM
  #37
gdstock's Avatar
gdstock
Does fan come on 100% or at a lower speed when it first kicks on? What is controlling it? Is it adjustable?
Old Jul 19, 2012 | 05:54 AM
  #38
Lemunman's Avatar
Lemunman
Its original radiator it's the efan 180 it is adjustable for different temps but it's only got one speed kickass fast till idle where thr my hid and underdrive pulley take me to about 10 amps .. No worries there I'm buying the 180 amp high output alternator verysoon
Old Jul 21, 2012 | 03:23 PM
  #39
Lemunman's Avatar
Lemunman
Well I used the mech guage and.... 20-25 idle and 55-60 at 3000 rpm so that beIng said all is well. Worries set aside .. Next tackle that clogged lifter thanks fellas
