A/C compressor woes (video attached)
Old Aug 1, 2012 | 01:09 PM
QuadCabLuv's Avatar
QuadCabLuv
Default A/C compressor woes (video attached)
A/C compressor runs with the clutch engaged at idle, but when you apply throttle the clutch disengages. When the compressor is running, it does make some noise. I am hoping that i cann replace just the clutch, but im thinkin that the bearing may be going out on compressor. I have attached a video showing what it is doing along with low side pressure readings. What are yalls suggestions?
<a href="http://s381.photobucket.com/albums/oo259/QuadCabLuv/?action=view&current=211a4631.mp4" target="_blank"><img src="http://i381.photobucket.com/albums/oo259/QuadCabLuv/211a4631.mp4" border="0" alt="Photobucket Pictures, Images and Photos" /></a>
Old Aug 1, 2012 | 01:10 PM
QuadCabLuv's Avatar
QuadCabLuv
Sorry here is link to video.
http://i381.photobucket.com/albums/o...v/211a4631.mp4
Old Aug 1, 2012 | 02:50 PM
1stGenDak's Avatar
1stGenDak
I had my compressor clutch springs break on my dakota a while ago and was hoping I could just replace the clutch/bearing assembly but I couldn't find a place that was reasonable. I just swapped out the whole compressor and recharged the system. Only cost $85 including the used compressor.
Sorry I couldn't help more,
Zac
Old Aug 1, 2012 | 03:54 PM
QuadCabLuv's Avatar
QuadCabLuv
Im wondering whats causing it to cut off when i apply throttle. Is it just cause the clutch is going out or is it a freon level issue?
Old Aug 1, 2012 | 04:05 PM
Put gauges on it, and see what your pressures are doing.
Old Aug 1, 2012 | 05:40 PM
QuadCabLuv's Avatar
QuadCabLuv
I did that is what the video is of. Watch it and tell me what you think.
Old Aug 1, 2012 | 06:06 PM
Oil pressure going down when you rev the engine indicates that the pickup is getting plugged up again. or oil level is low.......
If the valley is really grodie.... and is trapping oil up top, that's gonna be a problem. I would yank a valve cover, and see what the drain holes in the heads look like as well. Might be able to see into the valley, with a bright light.... worth a shot.
Old Aug 1, 2012 | 07:26 PM
ReadRam's Avatar
ReadRam
Get a feeler gauge and check airgap between clutch plates, Should be .01 to .031 in, If out of spec clutch won't stay engaged even if system is properly charged and all other components are in working right. You can check it right on truck.
Old Aug 1, 2012 | 08:31 PM
QuadCabLuv's Avatar
QuadCabLuv
I think your confused....
QuadCabLuv's Avatar
QuadCabLuv
I will try to find some time tomorrow to check this. Thanks for the tip.
