Best way to install trans cooler?
Old Aug 2, 2012 | 04:50 PM
Ryandodge2's Avatar
Ryandodge2
Default Best way to install trans cooler?
I would like to put a trans cooler on my truck, but whats the best way to install it? can you just cut the hard lines and put the line over those with clamps?
Old Aug 2, 2012 | 05:00 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Lots of threads on this. What did you put in the "Search" for keywords?
Edit: some good hits using "cooler"
https://dodgeforum.com/forum/search....archid=3987798
Old Aug 2, 2012 | 05:17 PM
wjxavier's Avatar
wjxavier
what i ended up doing was swedging the cooler lines and running rubber hose with double clamps lol hasn't leaked since and its been 3 years. lol
Old Aug 2, 2012 | 05:44 PM
zman17's Avatar
zman17
Retired Moderator - RIP
This is the best way. http://dieselmanor.com/dm_products/FTG-MFD.asp
Old Aug 2, 2012 | 09:49 PM
dhvaughan's Avatar
dhvaughan
that's what i did. use a tubing cutter for clean cuts. throw away the check valve. throw away the factory hoses with the quick connects.
https://dodgeforum.com/forum/2nd-gen...ter-added.html
zman posted a link to a temp sensor adapter.
Old Aug 2, 2012 | 10:22 PM
Ryandodge2's Avatar
Ryandodge2
Thanks guys appreciate it! Sorry I searched trans cooler and
Didn't seem to get much.
Old Aug 2, 2012 | 11:10 PM
gdstock's Avatar
gdstock
I put mine inline with radiator cooler for added cooling.
Old Aug 2, 2012 | 11:45 PM
QuadCabLuv's Avatar
QuadCabLuv
Yeah do not bypass radiator unless you have a trans temp gauge to monitor it.
Old Aug 3, 2012 | 02:53 PM
zman17's Avatar
zman17
Woops, sorry. You are right dhv, I read too quick. But, a trans temp gauge is just as important. And that's what you want to use if installing one.
