Shutter-Hesitation-Misfire
Old Aug 28, 2012 | 10:47 AM
  #121
jondakotaguy's Avatar
jondakotaguy
That's kinda weird.. the fuel pump is going to maintain a certain pressure.. I would assume that if it was the fuel pump causing this idle issue; it would be even worse under throttle and increase in demand for fuel..
Old Aug 28, 2012 | 11:39 AM
  #122
It's Me Patt's Avatar
It's Me Patt
+1..even more so knowing my pump/filter is an assembly..if anything I think it would be a fuel pressure regulator problem..probably just me tho
Old Aug 28, 2012 | 02:14 PM
  #123
pipeliner798's Avatar
pipeliner798
same symptoms as my chevy it would reak of gas when running i swore it was flooding out but after a new pump and sending until it runs like a champ a good pump will maintian pressure but if it is shot it will cause these problems
Old Aug 29, 2012 | 09:23 AM
  #124
jondakotaguy
Yeah I agree pipe i could.. but also when you put your foot off into it it would be puttering the whole way.. I don't have nothing like that honestly.. My truck will still throw you in the seat.. so it's getting plenty of fuel.. and most likely in our case is not our problem.
I think I've pretty much narrowed it down to either some sort of EMI to the lines; causing a weird timing issue... or some problem with the valves, rocker arms or timing chain something along these lines.. that is messing with the timing.. my throb is in sync with my exhaust. It's something with the engine. Maybe the exhaust side on number 7... I'm really not sure.
I'm going to try and seafoam really well.. Last time i engine tuned the cyl.. at the direction of my brother but never sea foamed.
Old Sep 10, 2012 | 06:49 PM
  #125
It's Me Patt
This thread, isn't dead, just dormant Has gone way off the topic, so sorry about that..I will keep it to the shudder problems as much as possible...good luck with yours and I'll post updates asap
Old Sep 18, 2012 | 12:25 PM
  #126
yellowtruck's Avatar
yellowtruck
I have the same shutter problem. Did you ever replace the crankshaft position sensor. Thats my plan next. My problem is it shutters from 45mph on no matter how fast i go.
Matt
Old Sep 18, 2012 | 02:11 PM
  #127
Matt
If it starts as soon as you hit O/D.... then what you are feeling is a miss. Have you fixed your plenum? When was the last time the truck had a tuneup?
Old Sep 18, 2012 | 06:20 PM
  #128
jondakotaguy
I think we should consolidate all these threads into an all in one thread.. for these 2 issues.. Off Idle shudder and TCC Lockup Shudder.
Old Sep 18, 2012 | 10:13 PM
  #129
It's Me Patt
Matt
Yeah a mis will exaggerate the shudder symptoms..have you been having a no start..I haven't replaced the ckps but one of my buddys did and it didn't help..you have a way different issue..what other symptoms do you have?
Old Sep 19, 2012 | 10:02 AM
  #130
jondakotaguy
Free Bump..
I think the most important thing we can do is isolate other issues from the one's we are having and try and weed through what is and what's not the same issue.. then we can cross reference what everyone has already done and rule them out as possibilities.
Patt.. have you ever checked your timing? see if at idle vs.. 1100 if there is anything off about or.. advancing.. retarding.. randomly? That would explain a bad timing chain.. or iming in general. My light is broke (bulb?) and i cant find anew one cus it's old..
SO i have not tested mine..
