Advice on 2000 Ram 1500
Old Aug 5, 2012 | 05:04 PM
SteveR Rambin's Avatar
SteveR Rambin
Default Advice on 2000 Ram 1500
Hello All
A problem just popped up on my truck the other day and I would appreciate some advice. When I cranked it up the other day the "Brake" and "ABS" lights stayed on (brakes worked fine), then driving it I noticed the speedometer wasn't working either and then next the "Check Engine" light came on and remains on. Today I held in the trip odometer button in while turning on the key to get the error code, no code was displayed. If I did this correctly shouldn't the code show up during the self check?
I replaced the speed sensor on the transmission output last year when the speedo stopped working but I don't remember the brake lights being on. At that time an error code was displayed. Any ideas?
Thanks
Steve Rambin
Old Aug 5, 2012 | 07:55 PM
jasonw's Avatar
jasonw
Site Moderator
For future reference, please post in the appropriate section:
https://dodgeforum.com/forum/dodge-r...s-section.html
I will move this one for you.
Old Aug 5, 2012 | 08:09 PM
Ramzy's Avatar
Ramzy
Speed sensor on the rear diff...will fix you right up.
Old Aug 5, 2012 | 08:32 PM
Nereaga's Avatar
Nereaga
^^^ X2...it is located on top of the rear differential housing. Easy fix
Old Aug 5, 2012 | 09:07 PM
dhvaughan's Avatar
dhvaughan
welcome to df. fill out your signature with truck info.
pull the codes on the later models by turning ignition to on - off - on - off - on
test gauges by turning ignition on while holding in trip meter.
reset pcm and cel codes by disconnecting neg battery cable and turning on headlights for 30 sec. it drains capacitors and memory.
Old Aug 7, 2012 | 08:20 AM
SteveR Rambin
Thanks for all of the great info and moving my thread to the right place. I didn't spot the notice until after I posted ( I always read the instructions last).
Old Aug 8, 2012 | 07:43 PM
dhvaughan's Avatar
dhvaughan
glad you got your truck fixed, but post your solution back in the original thread rather than starting a new one. we're not smart enough to tie them all together.
Originally Posted by SteveR Rambin
Thanks to all for the bullseye advice (thread:Advice On 2000 Ram 1500). Removed the sensor and installed a new one, worked just fine. Cleared the codes as instructed and the truck is just like new again. It's great to have a place you can come to and get help. Thanks again.
Steve
Old Aug 8, 2012 | 08:42 PM
QuadCabLuv's Avatar
QuadCabLuv
and so future people with the same issue will know that thats what it was.
