Engine and Plenum fixes...
#21
That is your IAT sensor, It does not look like the F1 has a spot for it hmmmm. The M1 puts it right under the TB is there a spot to drill and tap threads into the adapter plate?
Don't worry about getting that other coolant plug out the block is 90% m/t now. No primer is needed but the parts have to be spotless and grease free, when I clean a block for paint I scrub it with paint reducer and scotch bright pads.
#22
Things ground to a halt today... And not for the best. Was cleaning the throttle body yesterday with a degreaser, but then got called into work. Forgot about it. Came back to it today, the entire thing is covered in a white crystaline substance that is not easily coming off... Not thinking this is a good thing.
InfO.
InfO.
#23
#24
I.... do not. Suggestions on where to get it?
And since it is such a large build up, will it have caused damage? Will the acid stop the chemical process or will I need to do something after it?
Well... I did want that Hughes Engines TB.... What a downer though, kinda puts me off for the night. Thanks for the info though, if I can find some...
InfO.
Edit: Just looked it up, hydrochloric acid. I can pick up some from the local home depot or rona. I'll give it a shot tomorrow when I'm off work.
InfO.
InfO.
InfO.
#26
Hey Merc,
Just wanted to say thanks for the advice. Cleaned up nicely. Looks darker now, but whatever. I'm hoping it's still useable, but more importantly, I am hoping it can still be swapped as a core as I want to install the Hughes Engines 52mm one once I get everything back together and next pay day hits
InfO.
InfO.
#27
Question about installing the brass nipples into the new intake. It says to use a thread sealant. Having never really played with this aspect of stuff, I looked around in my garage to see what I had. Found two products, both Permatex.
One is "Ultra Black":
http://www.permatex.com/products/aut...sket_maker.htm
The other is "Ultra Copper":
http://www.permatex.com/products/Aut...sket_Maker.htm
It seems perhaps a silly question to put out there, but since I don't typically use the stuff I figure it couldn't hurt to ask.
InfO.
InfO.
#28
#29
#30
Different part of the engine, but I've been eyeing it for a bit - thinking I should replace it. Concensus?
Looks like the bulk of it has been beaten and closed, and considering there appears to be a transmission cooler behind it before even getting to the radiator... might be blocking a fair amount of air flow. I could also be out to lunch. Thoughts?
InfO.
InfO.
