Crank No Start And Fuel Pump Constantly Running
Old 08-18-2012 | 01:11 PM
Ok, the odometer trick just tests the cluster. Doesn't give PCM codes. Key trick doesn't seem to work on the 98's either... (so far as I know.) Need to plug a scanner in, and see what it has to say.
Old 08-18-2012 | 01:50 PM
zman17's Avatar
zman17
Retired Moderator - RIP
+1.... need a scanner for 98's and some real early 99's.
Old 08-18-2012 | 08:09 PM
JamesK's Avatar
JamesK
OK I will try to find or rent a scanner and see if it can lead me in the right direction.
Old 08-20-2012 | 09:34 PM
JamesK's Avatar
JamesK
Update!
Been screwing around with some things the last couple days with no luck...Until today!
Opened my fuse panel up in the engine bay and wiggled the big inline plug and noticed it wasn't very tight. Took it off and looked fine, tightened it back up, hooked up the battery again the she fired right up. Hoping that was it!
Old 08-20-2012 | 10:54 PM
gdstock's Avatar
gdstock
What "big inline pulg" are you talking about? Photos?
Old 08-20-2012 | 11:20 PM
JamesK's Avatar
JamesK
Its the big plug with the bolt holding it down. Says Engine Inline on the Cover
