transfer case compatibility
Old Nov 16, 2019 | 06:26 PM
Defiant6825's Avatar
Defiant6825
Default 2000 Dodge Dakota transfer case
Originally Posted by Defiant6825
Hi I just tried putting a 241 from a 2500 gas single cab in my 1500 extended cab and the out put shaft was different rear drive shaft is bigger yoke on rear end won't line up. Different animal.
Any one no what transfer case will work in a 2000 Dodge Dakota 4door v6 standard 5 speed .the case went chain broke but some one broke the I'd tag off so don't no what it is any ideas
Old Nov 16, 2019 | 07:53 PM
Probably the NV231D. Should be fairly common, as they were used in the half ton trucks as well. Keep in mind, you will want one from a 98 or newer truck, as quite a bit changed between 97 and 98.
Old Nov 17, 2019 | 09:25 AM
wca_tim's Avatar
wca_tim
I’d get the bigger yoke and a bastard ujoint to run the 241. Especially since you’ve already gone to the trouble of buying and putting it in. Its a good bit stronger case...
Old Jul 13, 2020 | 04:39 AM
Kyle Noe's Avatar
Kyle Noe
Originally Posted by Wombat Ranger
The output shaft for a 46re, NV3500, or NV4500 Light Duty (v8 version) is a 23 spline shaft, whether it's a 1/2 ton, 3/4 ton, or 1 ton.
Auto t-cases won't fit behind a manual, because they have a slightly longer input shaft, but manuals will be fine behind an auto. Either way, you could just swap the input from your original case to any dodge 231/241 and be safe.
Can i take a 231 and change chat a 241 with the speed sensor not being used
Old Jul 13, 2020 | 07:56 AM
I think there are differences in length between the two, won't matter for the front driveshaft, will matter for the rear.
Old Nov 21, 2022 | 09:55 AM
S H's Avatar
S H
Are you sure as every manual I have taken apart has a longer shaft and I've never seen an automatic with a long shaft only manuals auto transfer case will work in either truck manual or automatic but I don't think the manual transfer case will fit an automatic
Old Mar 16, 2023 | 09:28 PM
Dramhemi57's Avatar
Dramhemi57
Default Transfer case swap
Should be the same. If the input is different, swap it. They will interchange, and it's easy.
will a transfer case out of a 2002 ram with 4.7 automatic work with a 2002 ram with 5.9 both are floor shift trucks
Old Mar 16, 2023 | 09:31 PM
S H's Avatar
S H
Should be the same transfer case
Old Mar 16, 2023 | 10:06 PM
Dramhemi57's Avatar
Dramhemi57
ok awesome now all I need is tranny for 5.9
Old Apr 26, 2023 | 11:01 PM
Killerphoenix's Avatar
Killerphoenix
Default Transfer case compatibility
Can a transfer case from a 96 dodge ram 1500 with a 4 speed automatic convert over to a 95 ram 1500 with a 5 speed manual
