transfer case compatibility
Old Apr 26, 2023 | 11:22 PM
  #21
S H's Avatar
S H
Originally Posted by Killerphoenix
Can a transfer case from a 96 dodge ram 1500 with a 4 speed automatic convert over to a 95 ram 1500 with a 5 speed manual
As long as it has a speed sensor in the tail shaft like the other one then yes it's probably the same transfer case currently, as the 4spd is not original in a 2nd gen ram it was most likely put in from a 1st gen ram as I have done that same thing as long as the transfer case is the same then yes it should fit with no issues
Old Apr 27, 2023 | 09:42 AM
  #22
Keith_L's Avatar
Keith_L
Post #6 indicates tailshaft length of the transmission may be a problem
Old Apr 27, 2023 | 09:54 AM
  #23
Probably the same t-case.
Old Apr 27, 2023 | 12:44 PM
  #24
S H's Avatar
S H
Tail shaft length of the transmission will only matter when your trying to use the transmission and transfer case then it would make the driveshaft too short but if your using only the transfer case and the original driveshaft from the 5spd in the 5spd again there should be no issues and it is probably the same transfer case or else it probably has the 208 transfer case only way to know is get under it and find the tag and the numbers and see if they match
Old Apr 27, 2023 | 10:05 PM
  #25
Keith_L's Avatar
Keith_L
This feels like a Kamala moment?
Not sure what you're talking about?
How does tailshaft length of the transmission which lives within the t-case planetary affect driveshaft length at all? Or are you saying t-case adapters aka tailshaft housings are different lengths?
"This moment that we are in is the time that we are in and we should recognize the significance of this time and this time is today and is not the future but is today."
Yes??
Old Apr 27, 2023 | 10:17 PM
  #26
S H's Avatar
S H
[QUOTE=Keith_L;3565588]
As long as the transfer case length is the same which it should be and has the same yolk setup on the back of the transfer case will fit the bolt pattern is the same transmission to transfer case 4spd and 5spd have the same 6 stud pattern it is the same the transfer case should be the same unless someone has changed it with a 208 out of an older truck the 4spd was most common to have a 208 or 205 out of a 1st gen ram behind it as that's what the 4spd is most likely out of but they were a bolt on style flange as long as the transfer case is a slip yolk style like what should be on your 5spd 2nd gen ram it will work if this does not make sense to you please provide pictures of the back of both transfer cases and one of us can tell you if it will work or not
Old Apr 28, 2023 | 01:30 AM
  #27
HeikIlm's Avatar
HeikIlm
Firstly, use punctuation. That's really hard to read w/o of it.
Secondly, Killerphoenix was talking about 4 speed automatic transmission:
Old Apr 28, 2023 | 01:41 AM
  #28
S H's Avatar
S H
Sorry used to just typing and reading without any punctuation just how I've always done and everyone around me always have done🤷 but my bad on that,🤦🤦 I some how over read it being an automatic don't know how I managed that when I read it 4 different times🤦 same transfer case
