Yep. Spray as much as you can OUT of the engine, wash the rest down the oil drain holes, with the oil pan off, it will run right out, and clean out other stuff on the way down. Probably wouldn't hurt to pull the intake, and clean that area as well. (and fix the plenum if you haven't already)
Please have some sort of drip tray under the engine while you do this......
yea one more question bout doing this, wont the brake clean dry up my valve seals
Pull the oil pan and get to work with some Kerosene or Diesel. That's fugly dude!
i was told the same thing by my dad and old auto shop teacher. drain oil fill with Kerosene or Diesel and run engine for about a minute then drain Kerosene or Diesel, change filter add oil and drive around the block and then do another oil and filter change.
I've seen too many engines smoked by such behavior.......
As for the valve seals, they are probably already dried up. Good chance to change 'em out here......
