Sludged up!!!
Old Sep 6, 2012 | 07:33 PM
DodgeTh1s1's Avatar
DodgeTh1s1
Default Sludged up!!!
Any quick and easy suggestions, im open to anything, how well does seafoam work, will a brief change of oil with instead of 5 qts oil, 3 qts oil 2 qts transmission fluid, then re change the oil, im just lookin for a quick fix till can i afford new heads an so on.
Old Sep 6, 2012 | 07:49 PM
gdstock's Avatar
gdstock
Whatever you do, I would pull the pan and clean it out and then clean engine anc change oil pump and pick up. That has to be all over inside everything.
Old Sep 6, 2012 | 07:52 PM
DodgeTh1s1's Avatar
DodgeTh1s1
yea i do plan on dropping the pan, just in a bit of a financial crunch right now so you know i gotta put my project on the back burner.
Old Sep 6, 2012 | 07:54 PM
DodgeTh1s1's Avatar
DodgeTh1s1
this was my first vehicle, i had it all through high school so it hold so sentimental value, i just feel like im running out of time
DodgeTh1s1's Avatar
DodgeTh1s1
it has not even been on the road for like 3 years total now
Old Sep 6, 2012 | 08:04 PM
Adobedude's Avatar
Adobedude
That's beyond sea foam or anything else you pour in there.
Old Sep 6, 2012 | 08:23 PM
95RAM360's Avatar
95RAM360
You need some professional cleaning seafoam wont even crack the surface of that...
But i have seen worse on an old 2nd gen ram in a garage i use to work at....he had the upwards of 190k.....he still ran it up until i moved last year...so he had been driving it over a year with more sludge than yours....thought id share in hopes to make you feel better....
But that sludge is due to poor maintenance....have you been neglecting the ol girl?
Old Sep 6, 2012 | 09:57 PM
stewie01's Avatar
stewie01
Pull the oil pan and get to work with some Kerosene or Diesel. That's fugly dude!
Old Sep 6, 2012 | 10:09 PM
Brake or Carb cleaner would work too.... definitely drop the pan, and spray things out...
Old Sep 7, 2012 | 07:44 AM
DodgeTh1s1's Avatar
DodgeTh1s1
yea i neglected it while i was in high school i regret it know, but its too late now
