Sludged up!!!
Old Sep 7, 2012 | 04:03 PM
  #21
crazzywolfie's Avatar
crazzywolfie
I've seen too many engines smoked by such behavior.......
As for the valve seals, they are probably already dried up. Good chance to change 'em out here......
i guess it is like every engine additive. you take a gamble. i know you can find lots of people who blame putting sea foam in there oil for there engine dying but then there is lots of people that do it properly and all goes well. now saying all that i have filled the engine in my 81 with gas on a couple different occasions and it still ran good.
Old Sep 7, 2012 | 04:19 PM
  #22
Adobedude's Avatar
Adobedude
i was told the same thing by my dad and old auto shop teacher. drain oil fill with Kerosene or Diesel and run engine for about a minute then drain Kerosene or Diesel, change filter add oil and drive around the block and then do another oil and filter change.
Really bad advice...
"Might" work on a solid lifter motor, ever really seen the inside of a hydro roller lifter? That's if the oil even makes it past the oil pick up after a kerosne rinse.
Best is to pull the pan and wash the motor out, or even better pull the motor and take apart for a cleaning.
Old Sep 7, 2012 | 04:34 PM
  #23
stewie01's Avatar
stewie01
Just had a thought, might even be a worse idea then the kero or diesel. What if you, drained the oil, dropped the pan (for a more complete drain), put pan back, then use a de-greaser like PurplePower (NOT with the engine running) but more for soaking? Let it soak for a day or so, whatever it takes...
Then drain, fill with cheap **** oil, run for a little bit, drain again (may repeat once or twice more...) Then a regular oil change...
Thoughts or another blow it up type deal?
Old Sep 7, 2012 | 06:29 PM
  #24
I would trust that method more than putting something other than oil in the pan, and actually running the engine.
Old Sep 7, 2012 | 10:23 PM
  #25
Adobedude's Avatar
Adobedude
I really think all motors should come with a plate on the oil pan so you can pull it off and clean the oil pick up...Here's the oil pick up on my stock bottom 360 that came out of my Dakota drag truck...Looks like the occasional 7200 RPM blast in the water box was killing the valve seals
Old Sep 7, 2012 | 11:31 PM
  #26
gdstock's Avatar
gdstock
Now THAT'S pretty fugly! Was it still running?
Old Sep 8, 2012 | 12:09 AM
  #27
DodgeTh1s1's Avatar
DodgeTh1s1
Originally Posted by VWandDodge
With all of the ****-ant fixes you guys are suggesting, his best bet is to pull the engine and do a complete refurbishment of it.
i would do that if i had the equipment and time i have to know how just none of the others
Old Sep 8, 2012 | 12:10 AM
  #28
DodgeTh1s1's Avatar
DodgeTh1s1
are you talkin bout fillin the whole entire motor with purple power like pan to valve cover or what/
Old Sep 8, 2012 | 12:12 AM
  #29
stewie01's Avatar
stewie01
Yup. It would take a lot of PurplePower (or whatever you use) but give it a day or two to soak it should do a pretty good job cleaning.
Old Sep 8, 2012 | 08:46 AM
  #30
Adobedude's Avatar
Adobedude
Ran like a top, great oil pressure too...I was surprised when I saw it. Looks like the retainers were making contact with a few of the valve seals hence all the green plastic & springs on the pick up.
