Broken plug #4cyl
Old Sep 9, 2012 | 06:51 AM
eblack's Avatar
eblack
Default Broken plug #4cyl
So I broke the plug on my 96 ram 5.9 in # 4 cyl, the treads was the only thing left. So I took my time drilling then ran the 14mm tap down through, new plug went in with no prob, the truck runs great but I noticed some bubbles (leak) at the seat of the plug where some left over pb blaster was. Should I have drilled it big enough for a thread insert? Or just double the plug washer?
Old Sep 9, 2012 | 10:04 AM
It's Me Patt's Avatar
It's Me Patt
Maybe try a few turns around the threads with teflon tape 1st...
Old Sep 9, 2012 | 11:58 AM
zman17's Avatar
zman17
Retired Moderator - RIP
So now that any chemicals have burned off, is it still bubbling?
That would last about 5 seconds.
Old Sep 9, 2012 | 03:01 PM
It's Me Patt
Not it the truck is off It's safe to 500*f and depends which one you use it can sustain even higher temps...but drive the truck for an hour then pull the plug..it's not close to that temp, correct? If not he could use a tangless helicoil or am I off with that one too? Go mets
Old Sep 9, 2012 | 03:47 PM
eblack's Avatar
eblack
@ Zman not bubbling any more cuz the chemical is all gone, It bubbled as soon as I started it so I just assumed it was a leak. @ Pat, I would have thought the same thing about the teflon. I have tape I got from Lowes so I'm going to give it a try. Thank you guys!!!!!!!
Old Sep 9, 2012 | 07:30 PM
It's Me Patt
Could still be a leak..not sure what would be best to test it with, dishsoap is usually good to test with but not sure in this situation tho..Maybe zman will offer something better..he knows his stuff and way more than me! good luck...
Old Sep 9, 2012 | 08:02 PM
I wonder if the bubbling initially was from the liquid simply boiling off.......
Old Sep 10, 2012 | 04:43 AM
eblack's Avatar
eblack
I thought that to, but would it boil right at start up?
Old Sep 10, 2012 | 06:58 AM
Hhhhmmm. probably not..... I am not even entirely sure just how hot it gets there.... though I would image "fairly hot" would describe it pretty well...... hit it with a temp gun, and see.....
Old Sep 10, 2012 | 06:23 PM
zman17's Avatar
zman17
If the seat was clean and the plug was torqued to spec, there no problem. It was just the chemicals you used burning off(which won't happen instantly). Spray the same chemicals down one of the other plug tubes. I'm thinking it will bubble too for a period of time..
