Transmission extension housing
Old Sep 9, 2012 | 03:25 PM
Byron71's Avatar
Byron71
Default Transmission extension housing
I am putting on the extension housing on the transmission and it gets to one inch from the tranny and stops and will not go any further any suggestions
Old Sep 9, 2012 | 05:50 PM
What year truck? Which trans? 2 or 4 wheel drive?
Old Sep 9, 2012 | 07:15 PM
Byron71's Avatar
Byron71
97 ram 1500 don't know what transmission but has the shift rod out of the tranny and slides into the housing sorry new to this mechanic work
Old Sep 9, 2012 | 07:18 PM
gdstock's Avatar
gdstock
Automatic transmission?
What did you do to it?
That is probably the park rod, which goes in easiest from the front tinto the rear housing...
Old Sep 9, 2012 | 08:08 PM
Byron71's Avatar
Byron71
automatic 4x4 I did nothing to it just pulled it off by accident replacing the transfer case
Old Sep 9, 2012 | 08:22 PM
Are you trying to put the housing back on by itself, or, is it still attached to the t-case?
Old Sep 9, 2012 | 08:32 PM
Byron71's Avatar
Byron71
By itself it will go on except for the last inch and an eigth I measured it I pulled it off it came off easy now I can't seem to put it back on worked five hours on it yesterday and still can't figure it out very frustrated
Old Sep 9, 2012 | 09:00 PM
QuadCabLuv's Avatar
QuadCabLuv
Make sure the dowel pins are going in straight, you may even need to hit them with some sandpaper or emery cloth if they have burrs on them. Try tapping it down with a hard rubber mallet without the bolts in.
Old Sep 9, 2012 | 09:11 PM
Byron71's Avatar
Byron71
Were are these dowel pins all that's sticking out is the shaft from the tyranny with splines on it and this housing is a box with gears in it that this shaft goes in in there is the female with the same spline pattern as the shaft I get it on there except for the last inch
Old Sep 9, 2012 | 09:17 PM
Did you take off the O/D unit??? Might have to twist it a bit back and forth to get things to line up again.
