tire cuping
Old Sep 20, 2012 | 09:09 PM
homeboysduster's Avatar
homeboysduster
Default tire cuping
Ok, I have replaced ball joints,wheel bearings,idler arm,and pitman are on my 98 2wd with a 5.2 auto sport. I am on my 2nd set of tires and they are cupped again!!! any help or ideas welcome!!!
Old Sep 20, 2012 | 09:11 PM
mantisman51's Avatar
mantisman51
OK, I just read the bearing part. Were they properly torqued in the two-step process or just tightened down like a gorilla? It makes a huge difference.
Old Sep 20, 2012 | 09:14 PM
Cupping is generally caused by bad/weak shocks.
Old Sep 20, 2012 | 09:21 PM
homeboysduster
I always to the 2 step. LOL! I learned that lession about 20 years ago when I burned up the new bearings in my newport!!LOL
that is something I haven't done! I will have to see how well it bounces!!
Old Sep 20, 2012 | 09:23 PM
Matt Nickerson's Avatar
Matt Nickerson
Bent a control arm maybe?
Really bad alignment?
Old Sep 20, 2012 | 10:59 PM
kejobe's Avatar
kejobe
I second the shocks.
Old Sep 21, 2012 | 10:57 AM
jondakotaguy's Avatar
jondakotaguy
Improper tire rotation as well.
Old Sep 21, 2012 | 01:18 PM
Sooper's Avatar
Sooper
Shocks and 'good' alignment.
Old Sep 21, 2012 | 04:44 PM
sungod's Avatar
sungod
My money is on alignment. How often do you have it checked?
Old Sep 21, 2012 | 07:55 PM
Cupping is from the tires bouncing/vibrating. Shocks.
If it were an alignment problem, the wear would be relatively even around the tire.
