Either that 5.9 is swapped in, or your buddy has mistaken his 5.2 for a 5.9. 5.9 ZJ's were '98 only.
Either way, the worthless cold air intake will fit your throttle body, but might not mount correctly on the filter end. Why don't you just go try to test fit it?
True but the Ram has a wider more open space on the same side, so the CAI would have plenty of room if im not mistaken. So in theory it should work right?
It wont work. The air hat itself may be the same part(which I also doubt, probably shorter), but the air cleaner end is totally different.
