CEL code P1740 - What should I do?
Old Sep 26, 2012 | 07:54 PM
It's Me Patt's Avatar
It's Me Patt
Thoughts, advice on replacement or cleaning them? and yes i'm scared there's some other parts I wanted to check/replace and have to drop the VB...
Old Sep 27, 2012 | 09:20 AM
Nsmitty21's Avatar
Nsmitty21
Great videos, both of them. I ordered the TCC solenoid and hopefully will replace it this weened if it gets here in time. Thoughts on just cleaning the Gov control solenoid? How do you clean it, just flushing it out with some tranny fluid?? Also, how much tranny fluid will I need to buy? I forgot how much it took with my filter change a while back.
Old Sep 27, 2012 | 10:10 AM
It's Me Patt
Mine takes four qts for a change and I keep an extra on hand...which is an approx for you, as there are a few factors to consider such as having an aux cooler..you just don't want to overfill is all I'm saying and use the correct type of course..as far as cleaning, not 100% so can't say..I hear ya tho rock auto wants about $100 for it
I'd google search it..
Old Sep 27, 2012 | 11:05 AM
Nsmitty21's Avatar
Nsmitty21
For some reason I though I bought 4 when I changed mine last time originality but I remember adding a pint or so like ever day for a week! Mine does have an aftermarket cooler too though.
Yeah for $100 I figured I would give cleaning it a try and see how that works. Man I hate working on trannys and all this electronic stuff!!
Old Sep 28, 2012 | 09:52 AM
It's Me Patt
Sure I'm stating the obvious but after drain/fill, need to drive and get it to op temp. Check fluid in N gear (w/e-Brake on) on a flat surface after shifting through gears too..GL and post up your results
Old Oct 12, 2012 | 05:05 PM
Nsmitty21's Avatar
Nsmitty21
So I changed my TCC solenoid and it seemed to do a little better but still had some RPM jump like it didnt want to lock up all the way. Then today my CEL light came on again with the same P1740 code. Does anyone have any other suggestions or should I just start saving for a rebuild???
Old Oct 13, 2012 | 12:31 AM
gdstock's Avatar
gdstock
What did you find in the pan? Anything more than just a bit of gray sludge on the magnet?
It is sometimes difficult to get the VB cleaned out so there could be more in there that is effecting lockup. Also, check the connector real good. If it is not good and tight it could cause an issue.
