Turn-signal lights stay on when activated...
Old 09-28-2012, 08:20 PM
cngizbleevng's Avatar
cngizbleevng
cngizbleevng is offline
Default Turn-signal lights stay on when activated...
My '96 ram has an odd turn-signal problem. When I activate the signal on either side, the lamp on the dash stays lit instead of blinking, and the exterior light stays lit instead of blinking too.
I haven't had a chance to check the fuses yet, but I'm assuming if the fuse was blown the lights wouldn't come on at all.
Any ideas?
Old 09-28-2012, 08:24 PM
stewie01's Avatar
stewie01
stewie01 is offline
Check all the bulbs for loose/dirty connections.... Probably wouldn't hurt to check the ground connections too.
Old 09-29-2012, 01:13 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
Replace the flasher.
Old 09-29-2012, 06:21 PM
gdstock's Avatar
gdstock
gdstock is offline
+1 on flasher. If it was bulb realted, it woud flash at a fast rate...
Old 09-29-2012, 08:18 PM
horatio102's Avatar
horatio102
horatio102 is offline
What those two said. Your flasher isn't flashing, it's just turning on.
Old 09-29-2012, 08:40 PM
cngizbleevng
when you say 'replace the flasher' are you referring to the stalk on the steering column, or is there another relay or component you're referring to?
Old 09-29-2012, 08:42 PM
gdstock's Avatar
gdstock
gdstock is offline
Do you have an owners manual? Haynes or other shop manual?
You can download service manual here on DF in the FAQ/DIY section. It will show you what it is. Local auto parts store can probably show you when you go there to buy it.
Old 09-30-2012, 01:32 AM
peshewa's Avatar
peshewa
peshewa is offline
Take off the disease cover with the door open. It looks like a relay but it is light blue instead of grey or black.
Old 09-30-2012, 12:03 PM
zman17's Avatar
zman17
zman17 is offline
No, the older models have 2 round silver flashers. One for turn signals and one for emergency flash.
Old 09-30-2012, 09:04 PM
cngizbleevng
Yes, I just checked the Haynes manual. Thanks for pointing me in the direction I should have known to take in the first place :-/
Quick Reply: Turn-signal lights stay on when activated...
