another dead ram
#41
I was wondering why that stuck in my head... Six dings is "put your damned seat belt on!" and two is "look at the dash!". Below an eighth of a tank, are ya?
#43
where did this come from
being my truck is still dead and sitting there looking all sad i decided to pressure wash the engine and under the truck as i was pressure washing Attachment 17504 the under side neer the back of the motor a spring feel out.its about 3 inches long with hooks at each end. im going to try and attach a pic of it so all u gurus can see if u know where it went.
Thanks
Thanks
#44
not that
i tried to crank it today after taking the dis cap off and spraying some contact cleaner in it and it tried to crank! for a sec then nothing else that was it. so im sure leaning to coil or cap. but we`ll see.
#45
#46
Thanks
Thanks
That looks like the TV cable return spring. Drive side of tranny where the TV cable attaches. Should be a small hole in the bracket and another one near the engine. Too dark outside or I would take a photo of how it installs.
#47
Were you wearing it when you did the unsuccessful key dance trick trying to pull the codes via the odometer?
Ennyhoo, two dings is the "look at the instrument cluster" alert. It could be for any idiot light or even a low gauge.
#48
as far as the 2 dings it did the 6 then 2 when it was running the dash gauges test when you hold the trip meter as you turn the key.everything on the gauges/lites work fine. but thatsnks for the tip.
#49
cool
if u can take a pic in the next few days thats fine, truck is still dead so its not going anywhere.i looked and cant see where it goes. this thing wouldnt be a reason for the truck not to start would it?
#50
hm
i see nowhere it may go, if by chance u can take a pic of it on your truck that would help. the service manual sure didnt help
