another dead ram
#91
tech i think i hear a sort of popping, but im also hearing something new like a bleed down of air.tomorrow after going for a job interview im going to start checking all the vacum lines i swear it sounds like air excaping then goes away slowly. i might try a old trick from the ol days mix a sprayer with dish soap and water then spray it on the lines/connections of vacums lines where you see bubbles you have a leak.
#92
just another code
well i think i got the P-0443 code fixed a loose vacume line comming from the gas tank was cracked.
Now the P0783 code, some kind of 3-4 shift code, alldata says it can be 3 or 4 things so being i already replaced every sensor and silanoid in the tranny and it shifts out fine im leaning to relays or something electrical.
#93
#94
So you replaced the O/D solenoid? What does the tranny fluid look/smell like when you have it warmed up and pull the dipstick? It could be a relay, but that would affect the whole transmission if it did. Another possibility is a bad internal tranny harness, faulty external main harness, a bad PCM, or a bad O/D range. Is the O/D light on when you initially start the vehicle? Also, is the tranny connector on the tranny tight?
#95
i check all connections tomorrow when i get under it.
#96
Tranny fluid is good only about 4 months old under 1000 miles on it, no lites come on at all, i took it out for a live data test on the code reader and while driving at 60 pushed the o/d botton to disengage the OD and the rpms went up as normal. so to me the tranny is working fine, normal rpms all seems ok there.
