transmission slipping please help!!!
Old Dec 4, 2012 | 10:48 PM
nathangoodwin's Avatar
nathangoodwin
New Member
Default transmission slipping please help!!!
i have a 1997 dodge ram 1500 4 wheel drive with the 318. sometimes when i get in it to drive in 2 wheel drive the tranny slips but then i can put it in 4 low and it will drive just fine? any ideas of what is wrong???
Old Dec 9, 2012 | 01:09 PM
jasonw's Avatar
jasonw
Site Moderator
For future reference:
https://dodgeforum.com/forum/dodge-r...s-section.html
Old Dec 9, 2012 | 01:33 PM
dlyter09's Avatar
dlyter09
how many miles on the truck? how is the fluid level? does it smell burnt or look dirty?
Old Dec 9, 2012 | 06:12 PM
nathangoodwin
New Member
150,000 miles new fluid and the fluid is full
Old Dec 9, 2012 | 06:14 PM
dlyter09's Avatar
dlyter09
Are you checking when in neutral and at normal operating temperature? If it is the stock transmission it may be getting close to rebuild time.
Old Dec 10, 2012 | 09:48 AM
nathangoodwin
New Member
yes it is in nuetral and on level ground. and i let it warm up for awhile. could it be the pump inside the transmission? and do you know about how much a rebuild kill would cost a person?
Old Dec 10, 2012 | 10:09 AM
Need to run it thru the gears, to make sure everything is filled up. If it's slipping, a band adjustment might get you a bit more time, but, better start considering a rebuild. Generally run around 1000-1500 bucks.
Old Dec 10, 2012 | 10:10 AM
gdstock's Avatar
gdstock
The pump is the least likely problem. And rebuild? The price varies so much, expect to pay anywhere between $1200 to $2500.
The price is partially a funcion of where you are located. And partially based on what the market will bear. Want to do it right - and never have to worry about tranny issues? Get a mega viper from PATC. But that is not cheap.
Old Dec 10, 2012 | 10:42 AM
nathangoodwin
New Member
where would i go to get the maga viper rebuild
Old Dec 10, 2012 | 11:04 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
You don't get a Mega Viper rebuild, the PATC Mega Viper is a full fledged replacement transmission.
Not cheap, about $3600 but can take whatever you can throw at it.
Only an option if you plan on keeping your truck for another 5 years.
